> Window Problem
post Apr 14, 2008 - 4:56 AM
808celi
Joined Nov 30, '05
From 8o8 StAte (Hawaii)
What's up everybody
I'm having a problem with my windows. both the passenger and driver windows won't go down. the power lock and windows don't work on the drivers side but the passenger side the window doesn't go down but the power lock works on the passenger side. I think its the window fuse that blew. does anyone know which fuse this is?
post Apr 14, 2008 - 6:16 AM
there is a window lock button did you push it on accident?
also did you check to make sure your junk is plugged in under that panel?
post Apr 14, 2008 - 2:39 PM
cochise
Joined Nov 14, '06
From michigan
QUOTE(808celi @ Apr 14, 2008 - 9:56 AM) [snapback]664353[/snapback]
What's up everybody
fuse 16 in drivers side fuse panel
post Apr 14, 2008 - 3:37 PM
xs94st
Joined Aug 11, '07
From Corona, CA
x2 with wha playr said bout the plugs. did you do anything to your car recently as in taking off the door panels? maybe they aren't connected all the way.
Pandelica 2.0 in progress.
Lo-Fi Version Time is now: September 3rd, 2026 - 5:08 PM
