> Callipers, Seizing
post Apr 15, 2008 - 1:33 PM
Dell
Joined Feb 4, '07
From Ireland
Anyone have this problem ? Is there a service kit you can get for them ?
post Apr 15, 2008 - 1:52 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
easiest to get a new caliper
there are some places in the states that will rebuild them for you, but a new caliper shouldn't be more than $100usd
post Apr 16, 2008 - 5:04 PM
alltracman78
Joined Aug 9, '06
From Ma
Ouch.
Parts are going to be expensive for you.
You can buy a rebuild kit, but first you need to find out if it's actually rebuild able.
Depending how bad and where it's seized you might be better off just replacing them.
post Apr 16, 2008 - 8:07 PM
QUOTE(alltracman78 @ Apr 16, 2008 - 6:04 PM) [snapback]665297[/snapback]
Ouch.
there is a rebuild kit, not that expensive. call the dealer. I dont have part number...
post Apr 17, 2008 - 2:57 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Or if you don't mind aftermarket, there's caliper rebuild kits available from just about every auto parts store.
Basically comes down to your ability to remove the seized parts. I had to use a punch and hammer to remove seized bushings in my calipers, but it was otherwise a fairly easy rebuild. On the other hand, you could have one seized so badly it'd take a machine press to separate the parts. At that point, it's just a core to exchange for a remanufactured caliper (which is basically a caliper rebuilt by professionals).
www.1sttoyotaparts.com if you want genuine Toyota parts. You could even get the rebuild from them if desired -- what isn't listed on the website is available by calling them, just mention you're an internet order so you don't get charged as if you were a walk-in customer, as it is an actual dealership.
post Apr 17, 2008 - 8:29 AM
Dell
Joined Feb 4, '07
From Ireland
Stripped it down last night and had a look, one of the pistons was pretty much jammed solid. Got them out and cleaned everything up. Seems to be good enough anyway. Cheap and cheerful fix smile.gif
post Apr 17, 2008 - 11:38 AM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(njccmd2002 @ Apr 16, 2008 - 8:07 PM) [snapback]665373[/snapback]
Ouch.
If you took 2 seconds to look at their location, it's Ireland.
Everything's [relatively] expensive because it has to be shipped there, and it's not a large market......
post Apr 17, 2008 - 12:44 PM
QUOTE(alltracman78 @ Apr 17, 2008 - 12:38 PM) [snapback]665546[/snapback]
Ouch.
well, but i guess they will still have toyota dealers. over here in us is 20 bucks, so it cant be more than 30. Well he fixed it.... but i guess i did not realize he was irish. (saying it with irish accent)
post Apr 18, 2008 - 5:18 AM
Dell
Joined Feb 4, '07
From Ireland
Did I start a fight ? smile.gif Thanks anyway for the help.
Lo-Fi Version Time is now: September 20th, 2026 - 5:54 AM
