> Fuel filter noob question, order for 3sgte or 5sfe?
post Apr 20, 2008 - 3:37 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
I'm in the process of doing a full tune up on my car, and want to change the fuel filter, but am unsure of which engine I should order for.
The engine is a 93 3sgte, but since the fuel filter is not attached to the engine (such as cap/rotor/wires etc) do I still need to order a 3sgte fuel filter? Only looking to change the in-line filter for now.
post Apr 20, 2008 - 10:34 PM
malecrod
Joined May 30, '05
From MN
QUOTE(6gsillyca @ Apr 20, 2008 - 3:37 AM) [snapback]666340[/snapback]
I used the 5sfe fuel filter for mine and its running fine for about 7months now. I don't know if you can use the 3sgte fuel filter unless the fittings to the filter are the same as the 5sfe. If your lines are still 5sfe, I will just use the 5sfe fuel filter.
GL
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
post Apr 21, 2008 - 2:39 AM
Penkka
Joined Dec 20, '07
From Valkeakoski, Finland
Well atleast the 3S-GE and im almost sure that the GT4 has exactly the same oil filtter as every other Toyota.
320hp @ 6300rpm and 420Nm @ 3250rpm. yay!
My ST205 WRC buildthread
post Apr 21, 2008 - 11:44 PM
6gsillyca
Joined Jan 13, '06
So I called up 2 dealers today, and they both said that the filter is a non-service part. As in they didn't have a p/n. I even specifically stated I was looking for the inline filter, located in the engine bay, not in the fuel tank and it was no help...
I haven't been able to find it on any of my usual part websites either, so can someone throw a p/n for a 5sfe engine up?
Ugh, nvm about the p/n. I was being blond, and did not notice I was searching in the collision drilldown...
This post has been edited by 6gsillyca: Apr 22, 2008 - 12:13 AM
Lo-Fi Version Time is now: June 23rd, 2026 - 3:48 PM
