Apr 21, 2008 - 8:42 PM
Enthusiast Joined Apr 16, '08 From CT Currently Offline Reputation: 0 (0%) |
i got a 97 gt celica and im planning to put on an exhaust headers but a friend mine says i might fail an emissions test if i do this. anyone know anything about this?
This post has been edited by Dtuner17: Apr 21, 2008 - 8:49 PM |
Apr 21, 2008 - 10:57 PM
Enthusiast ![]() ![]() Joined Apr 18, '08 From Oakland, bay area, California Currently Offline Reputation: 1 (100%) |
you most likely will, since the stock internals are made to fit emissions test. However, it also depends on the state youre in. maybe you should check CT emission regulations before you do anything, especially since there are some things you can do to get around it..
i forgot which state it was in, but in that state, you only need to smog if you drive over a certain limit a year, in which they just switched the odometer and bam, they didnt need to smog. shh =) |
Apr 22, 2008 - 3:54 PM
here are the regulations for my state:
Parameters of the Inspection The emissions inspection includes the following tests: Gas cap leakage An onboard diagnostics exam for vehicles 1996 or newer An acceleration exam for vehicles 1995 or older An idling test for some vehicles will i be able to pass it with exhaust headers This post has been edited by Dtuner17: Apr 22, 2008 - 3:55 PM |
Apr 22, 2008 - 4:09 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Yes as long as they don't leak and you install an aftermarket Cat in replacement of the stock primary cat and route your o2 sensor(s) in the same spot relative to the cat as was the stock setup.
You may have a visual test you might fail tho - depends on the local laws. -------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Apr 22, 2008 - 4:15 PM
ok thanks for the help
| Lo-Fi Version | Time is now: May 10th, 2026 - 10:39 AM |
