Apr 27, 2008 - 9:30 PM
Enthusiast ![]() ![]() Joined Feb 6, '08 From charleston, sc Currently Offline Reputation: 0 (0%) |
umm...
1) my rear drums are squealing. ive cleaned the drums, changed the pads, and other things. what might cause this? 2) where can i find rear disk brakes? and for approximately how much? 3)i want to lower my car. do i needd shocks or can i just buy springs w/o shocks? and do i need s spring compressor to do this? ps. how do i add those things at the bottom? -------------------- myspace!!
go FULL THROTTLE or go home |
Apr 27, 2008 - 9:43 PM
Enthusiast ![]() ![]() ![]() Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
#1: Some pads squeal til they get totally seated. Many other possible reasons why as well, but it is probably that they aren't seated totally yet(depending on how long ago you put on the new brake pads)
Partial answer to #2: You'll have to do a rear disk conversion. There's quite a few threads stating what you'll need from a gt. Prices will vary on deals that you can get on the parts. #3: You can buy just springs, but if you still have stock shocks, might as well replace em while you're in there. A spring compressor will make the job a heck of a lot easier. Answer to the p.s.: Go to my controls, then signature(should be on the left hand side) then put in what you want -------------------- |
Apr 27, 2008 - 9:46 PM
Enthusiast ![]() ![]() ![]() Joined Apr 24, '07 From lufkin tx Currently Offline Reputation: 0 (0%) |
Well stickies may help alot on some of these....look into the how to section
On your lowering question....debaized is right on .......I suggest KYB gas struts i love them....as far as springs Eibach, Tein, Tanabe, depending on your budget maybe some adjustable coil overs if your swimming in money? yes you will need a spring compressor go to auto zone and borrow one. This post has been edited by Jared95: Apr 27, 2008 - 9:47 PM |
cool
will i **** up my car if i didnt put shocks on right away? -------------------- myspace!!
Apr 28, 2008 - 12:42 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
search up the stickies for diy install help.
im on tein springs with oem shocks. and guess what they're almost - blown too!!! -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
| Lo-Fi Version | Time is now: June 15th, 2026 - 8:39 AM |
