> Engine cleaning
post Apr 29, 2008 - 1:09 PM
kern
Joined Apr 21, '08
From uk
Gonna have a go at cleaning my engine bay on the weekend if the weather is promising, but my question is, would it be ok to get a power washer on it before i use start scrubbing and polishing?? its a budget power washer so not gonna rip things off...
post Apr 29, 2008 - 3:41 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
I sprayed simple green as a degreaser on most places except the fuel injector area and the distributor cap. I let it sit for 30 minutes then i went out there and had my power washer on like a med. setting. After i was done i took steal wool to the valve cover and injectors and such. Even got some of the tranny. I kept the car running when i did this. I didn't have a problem with anything after doing this.
2nd Gen 3s-gte.... It lives!
97celiman
post Apr 29, 2008 - 4:05 PM
kern
Joined Apr 21, '08
From uk
post Apr 29, 2008 - 4:13 PM
Insanity-74
Joined Jan 9, '05
From Under the car
If your gonna wash your engine do it when its warm (not hot) and try to avoid getting engine degreaser on the radiator...it wont do it any damage but it can stain it making it look ugly....also dont directly spry things like the dizzy, ignitor and electrical bits n pieces.
post Apr 30, 2008 - 1:03 AM
Rusty
Joined Nov 5, '07
From New Zealand
^cover those important pieces with a plastic bag or something
post Apr 30, 2008 - 4:41 AM
stevest202
Joined Oct 28, '07
From epworth uk
Autoglym engine and machine cleaner is good for removing grime (put clingfilm over sensitive electronic bits) once you've done that put some back to black type stuff on the hoses and don't buff off. Then go at the various manifold bits with a drill polisher and finish off with some Meguiars All Metal Polysh - so
post Apr 30, 2008 - 2:15 PM
kern
Joined Apr 21, '08
From uk
nice job, looks good with the blue bits
post Apr 30, 2008 - 4:35 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
One suggestion -- avoid the Mother's Back to Black, it has a tendency to turn plastic grey if not regularly re-applied. A rubber/vinyl preservative, such as Meguiar's 40 is a better choice.
Lo-Fi Version Time is now: May 18th, 2026 - 5:19 PM
