Apr 29, 2008 - 4:46 PM
Enthusiast ![]() Joined Feb 4, '08 From UK Currently Offline Reputation: 0 (0%) |
Hey, just bought an oil catch can - where is the best place to locate in on my 3SGE?
Initially I thought that it should bridge where the little tube coming from the rocker to the intake manifold usually sits. Top left, just in front of the oil cap, is this right? I noticed that it has a non-return valve but oil still gets through and if it is removed the idle is high!!!!
May 6, 2008 - 12:36 AM
Enthusiast ![]() ![]() Joined Aug 15, '07 From ATLANTA Currently Offline Reputation: 0 (0%) |
its like under neath the intake manifold well( like back of the engine where fuel lines are.. did u do the swap or u bought it like this? cuz i am doing that swap in my 94 St
-------------------- ![]() KEEPIN IT LOW... WAP PRODUCTIONS... www.myspace.com/waprod |
May 6, 2008 - 12:42 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
QUOTE(trdwasiq @ May 5, 2008 - 10:36 PM) [snapback]671038[/snapback] its like under neath the intake manifold well( like back of the engine where fuel lines are.. did u do the swap or u bought it like this? cuz i am doing that swap in my 94 St He's from the UK, where GT celica's come stock with the 3sge. anyway, I'm not too familiar with the engine, but if there is another hose that runs between your crankcase (probably valve cover) and your intake (either the piping or the manifold), other than the PCV valve, which as you said has a one way check valve, that would be the ideal place to put it between as that will be where most of the oil getting into your intake will be coming from. -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
| Lo-Fi Version | Time is now: September 1st, 2026 - 3:23 PM |
