> Rear drum to disc conversion question, Do I need to do anything with the master cylinder?
post May 2, 2008 - 7:00 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Someone told me he thought I will need to do something with/replace my master cylinder when I convert my rear drum brakes to disc brakes; something about the proportioning valve.
Here's what he said:
In regard to your brake swap, I could be wrong, but I'm almost positive that you'll need a different proportioning valve...When you do it, though, you should see about swapping the proportioning valve and
master cylinder (if it's different on the GTs)... Drum brake wheel cylinders and disc brake calipers use different amounts of fluid (typically) and if you swap from the former to the latter, your rear discs brakes won't be doing as much work as they should.
This is all greek to me. Help? Is this something I should look further in to?
- GriffGirl   Rear drum to disc conversion question   May 2, 2008 - 7:00 PM
- - njccmd2002   ok pretty much what he tried to say. you apply th...   May 2, 2008 - 7:37 PM
- - alltracman78   That's pretty much how it works. The P valve ...   May 2, 2008 - 9:32 PM
- - GriffGirl   Okay, so just to be perfectly clear. And btw I pro...   May 5, 2008 - 12:53 PM
- - GriffGirl   Okay, I found the proportioning valve on partsamer...   May 6, 2008 - 11:50 AM
- - DEATH   They [PV and MC] are the same. The only difference...   May 6, 2008 - 1:39 PM
|- - alltracman78   QUOTE (DEATH @ May 6, 2008 - 1:39 PM...   May 11, 2008 - 3:17 PM
- - GriffGirl   Yep, here I am. Part numbers for ST and GT P-Valve...   May 6, 2008 - 1:41 PM
- - alltracman78   Good to know. What I meant by the MC was that th...   May 6, 2008 - 10:28 PM
- - phantom   i replace my drums for disks and i think it brakes...   May 9, 2008 - 4:53 PM
- - GriffGirl   I'm researching this part - on 1stToyotaParts....   May 15, 2008 - 11:47 AM
- - alltracman78   For something like this you can't use the onli...   May 18, 2008 - 5:12 PM
- - GriffGirl   Bowchikawowow, my stuff came today!!! ...   May 21, 2008 - 1:22 PM
- - D-Man   YAY! for rear disks!!   May 21, 2008 - 1:48 PM
- - GriffGirl   Question: Is this the proportioning valve?   Jun 4, 2008 - 6:42 PM
- - alltracman78   Nope. That's just a side to side [front IIRC] ...   Jun 9, 2008 - 10:25 AM
- - playr158   proportioning vavle how it ties into the system...   Jun 9, 2008 - 10:56 AM
- - alltracman78   You don't have ABS. IIRC her "splitter...   Jun 9, 2008 - 9:41 PM
- - Batman722   I've done the drum to disk swap on 2 cars and ...   Jun 9, 2008 - 9:50 PM
- - GriffGirl   ^I have all of that stuff you listed. It was the p...   Jun 10, 2008 - 11:13 AM
- - alltracman78   QUOTE (Batman722 @ Jun 9, 2008 - 10...   Jun 16, 2008 - 5:49 PM
- - hurley97   I believe the only difference in the master cylind...   Jun 16, 2008 - 8:30 PM
- - GriffGirl   Saturday's the day! (bagging the P-valve f...   Jul 1, 2008 - 3:47 PM
- - GriffGirl   DONE!   Jul 7, 2008 - 3:38 PM
|- - BloodyStupidDavey   QUOTE (GriffGirl @ Jul 7, 2008 - 9:3...   Jul 7, 2008 - 3:58 PM
|- - GriffGirl   QUOTE (BloodyStupidDavey @ Jul 7, 2008 ...   Jul 9, 2008 - 6:24 PM
|- - BloodyStupidDavey   Awesome work, Michelle. And I know you are still ...   Jul 9, 2008 - 7:34 PM
- - GriffGirl   I'd love to, but currently my car is with the ...   Jul 7, 2008 - 5:17 PM
- - DEATH   You've risen another rung on the tuner ladder ...   Jul 7, 2008 - 6:00 PM
- - GriffGirl   Yeah, that's what she said.   Jul 7, 2008 - 6:21 PM
- - DEATH   I believe "pathetic" was the term used   Jul 7, 2008 - 6:24 PM
- - CelicaST_CALI   so deaths hows that 20 mpg going   Jul 7, 2008 - 7:07 PM
- - GriffGirl   RE: Rear drum to disc conversion question   Jul 8, 2008 - 12:14 PM
- - xs94st   good job with the conversion griff can't wait...   Jul 8, 2008 - 1:27 PM
- - GriffGirl   I don't actually have ABS, although I don...   Jul 8, 2008 - 2:08 PM
- - Batman722   glad you did the conversion GTs with ABS have se...   Jul 8, 2008 - 4:24 PM
- - alltracman78   Awesome, glad to see you got it sorted out. QUOT...   Jul 13, 2008 - 5:28 PM
- - GriffGirl   QUOTE (alltracman78 @ Jul 13, 2008 - 3...   Jul 17, 2008 - 1:43 PM
Lo-Fi Version Time is now: August 25th, 2026 - 6:39 PM
