May 3, 2008 - 8:55 PM
![]() Enthusiast ![]() Joined Oct 27, '07 From North Carolina Currently Offline Reputation: 0 (0%) |
Does anyone kno how to put an aftermarket shift boot in? it has an elstic base. I kno i have to make some mods to it, but just wondering if anyone knows the fool proof, correct way...
May 3, 2008 - 10:00 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Just unscrew your shift knob and pop out your shifter panel. You pull the panel with the factory boot intact and look underneath the panel. You will see that there is a rectangle shaped wire around the base of the boot to hold it onto the panel. Pop that out and fit your aftermarket shift boot on there.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
May 3, 2008 - 11:31 PM
I see. Thanks bro, much appreciated
May 9, 2008 - 12:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
If it's got an elastic base to it then what you'll need to do is pull your OEM shift boot out and rip the seam out of the base. After that is done you should have the metal base out of it. Then cut the elastic base off your new boot and (GASP) sew it back together.
It's pretty easy to do. I picked up a Honda Accord shift boot from a junkyard and sewed the two together to make a short shift boot. Looked great. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
| Lo-Fi Version | Time is now: September 19th, 2026 - 12:40 AM |
