May 4, 2008 - 1:32 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) |
I have a 94 1.8 St Celi that seems to make a grinding noise when I shift into 2nd gear. It does not always make this noise happens every once in a while when I get into the 5-6,000 rpm range. It gets really annoying and i really want to fix it. I'm just not sure if it will cost alot.
Also the same grinding happens when I try to shift down to 2nd gear going 40 mph. Its not like it doesn't go in but if i force it then it will make that annoying sound like metal against metal noise. This doesn't happend in any other gear but 2nd. For example when im on the freeway going 70 in 5th gear and i decide to go into 3rd it goes in smoothly with no problem. The same with 1st if i try to downshift into 1st gear going like at 25 it either wont go in or it does. But neither 3rd or 1st gear make any metal to metal sound, like a grinding noises. I would really appreciate anybodys help THANK YOU! -------------------- Group buy to replicate Narrow E series transaxle parts
http://www.6gc.net/forums/index.php?showto...p;#entry1107514 Items for Sale: http://www.6gc.net/forums/index.php?showto...p;#entry1107572 |
BonzaiCelica Shifting Up and Down into 2nd Gear May 4, 2008 - 1:32 PM
_mikeE Your synchro is worn in ur 2nd gear---2nd and 3rd ... May 4, 2008 - 1:49 PM
BonzaiCelica QUOTE(_mikeE @ May 4, 2008 - 1:49 PM... May 5, 2008 - 12:30 AM
_mikeE well you'll have to go to a transmission shop ... May 5, 2008 - 12:50 AM
BonzaiCelica I've noticed that when I heel toe when im shif... Jan 25, 2010 - 2:08 PM
nics that happened to me before shifting fr 2nd to thir... Jan 25, 2010 - 2:14 PM
rave2n Umm, I'm not expert, but from you've descr... Jan 25, 2010 - 2:47 PM
BonzaiCelica i recently change my tranny fluid about 7,000 mile... Jan 25, 2010 - 10:59 PM
rave2n QUOTE (BonzaiCelica @ Jan 25, 2010 - 10... Jan 26, 2010 - 8:47 AM
samir0189 QUOTE (BonzaiCelica @ Jan 25, 2010 - 11... Jan 26, 2010 - 11:29 AM
nics QUOTE (BonzaiCelica @ Jan 25, 2010 - 7... Jan 29, 2010 - 6:19 PM
keison2000 Do you really push your lil 7a to redline like tha... Jan 25, 2010 - 11:36 PM
Ruroniarc Rave2n is right, the 7afe doesn't have any per... Jan 26, 2010 - 10:01 AM
andreslr hey I have the same problem in 1st and 2nd. when i... Jan 26, 2010 - 5:07 PM
BonzaiCelica uhh hence, as to why I mentioned that I heeled toe... Jan 27, 2010 - 1:46 AM
samir0189 QUOTE (BonzaiCelica @ Jan 27, 2010 - 2... Jan 27, 2010 - 11:36 AM
GriffGirl Good god, remind me to never buy any of you guys... Jan 27, 2010 - 12:46 PM
nics QUOTE (GriffGirl @ Jan 27, 2010 - 9... Jan 27, 2010 - 2:09 PM
Supersprynt What oil are you using? Jan 27, 2010 - 1:42 PM
BonzaiCelica I'm using motul 75w-90 synthetic gear oil. cos... Jan 27, 2010 - 9:39 PM
VieT9sD mmmm i can't shift into 1st when the car is ab... Jan 29, 2010 - 7:39 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 12:41 AM |
