> Shifting Up and Down into 2nd Gear, Grinding Noise
post May 4, 2008 - 1:32 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
I have a 94 1.8 St Celi that seems to make a grinding noise when I shift into 2nd gear. It does not always make this noise happens every once in a while when I get into the 5-6,000 rpm range. It gets really annoying and i really want to fix it. I'm just not sure if it will cost alot.
Also the same grinding happens when I try to shift down to 2nd gear going 40 mph. Its not like it doesn't go in but if i force it then it will make that annoying sound like metal against metal noise.
This doesn't happend in any other gear but 2nd. For example when im on the freeway going 70 in 5th gear and i decide to go into 3rd it goes in smoothly with no problem. The same with 1st if i try to downshift into 1st gear going like at 25 it either wont go in or it does. But neither 3rd or 1st gear make any metal to metal sound, like a grinding noises.
I would really appreciate anybodys help THANK YOU!
- BonzaiCelica   Shifting Up and Down into 2nd Gear   May 4, 2008 - 1:32 PM
- - _mikeE   Your synchro is worn in ur 2nd gear---2nd and 3rd ...   May 4, 2008 - 1:49 PM
|- - BonzaiCelica   QUOTE(_mikeE @ May 4, 2008 - 1:49 PM...   May 5, 2008 - 12:30 AM
- - _mikeE   well you'll have to go to a transmission shop ...   May 5, 2008 - 12:50 AM
- - BonzaiCelica   I've noticed that when I heel toe when im shif...   Jan 25, 2010 - 2:08 PM
- - nics   that happened to me before shifting fr 2nd to thir...   Jan 25, 2010 - 2:14 PM
- - rave2n   Umm, I'm not expert, but from you've descr...   Jan 25, 2010 - 2:47 PM
- - BonzaiCelica   i recently change my tranny fluid about 7,000 mile...   Jan 25, 2010 - 10:59 PM
|- - rave2n   QUOTE (BonzaiCelica @ Jan 25, 2010 - 10...   Jan 26, 2010 - 8:47 AM
|- - samir0189   QUOTE (BonzaiCelica @ Jan 25, 2010 - 11...   Jan 26, 2010 - 11:29 AM
|- - nics   QUOTE (BonzaiCelica @ Jan 25, 2010 - 7...   Jan 29, 2010 - 6:19 PM
- - keison2000   Do you really push your lil 7a to redline like tha...   Jan 25, 2010 - 11:36 PM
- - Ruroniarc   Rave2n is right, the 7afe doesn't have any per...   Jan 26, 2010 - 10:01 AM
- - andreslr   hey I have the same problem in 1st and 2nd. when i...   Jan 26, 2010 - 5:07 PM
- - BonzaiCelica   uhh hence, as to why I mentioned that I heeled toe...   Jan 27, 2010 - 1:46 AM
|- - samir0189   QUOTE (BonzaiCelica @ Jan 27, 2010 - 2...   Jan 27, 2010 - 11:36 AM
- - GriffGirl   Good god, remind me to never buy any of you guys...   Jan 27, 2010 - 12:46 PM
|- - nics   QUOTE (GriffGirl @ Jan 27, 2010 - 9...   Jan 27, 2010 - 2:09 PM
- - Supersprynt   What oil are you using?   Jan 27, 2010 - 1:42 PM
- - BonzaiCelica   I'm using motul 75w-90 synthetic gear oil. cos...   Jan 27, 2010 - 9:39 PM
- - VieT9sD   mmmm i can't shift into 1st when the car is ab...   Jan 29, 2010 - 7:39 PM
Lo-Fi Version Time is now: August 27th, 2026 - 2:44 AM
