May 4, 2008 - 10:04 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
Where does this vac line run to/from? The one with the phillips pointed at it. It is labelled "3" and goes from the intake manni to a metal bracket attached to the fuel rail. I'm 99% sure it attaches to a T coming from my FPR, and shoule look like the 3rd pic. Is that correct? Can I eliminate the meat bracket attached to the fuel rail, and just run vac line from intake manni to the T?
![]() ![]() ![]() And these coolant lines run to the TB. Which one attaches to which nipple? ![]() |
6gsillyca 3sgte vac/coolant lines May 4, 2008 - 10:04 PM
lagos That vac line goes to a metal tube, that then goes... May 4, 2008 - 10:15 PM
6gsillyca Thanks. I wasn't sure if the metal tube was si... May 4, 2008 - 11:39 PM
lagos QUOTESo the coolant there isn't a "feed... May 4, 2008 - 11:44 PM
6gsillyca How hot does it get next to the fuel rail? Would m... May 5, 2008 - 11:21 PM
lagos QUOTE(6gsillyca @ May 6, 2008 - 12:2... May 6, 2008 - 7:22 PM
6gsillyca I was probably going to route it along the firewal... May 6, 2008 - 11:53 PM
lagos It goes to your greddy boost controller.
I never ... May 7, 2008 - 12:00 AM
6gsillyca What should I use to re-tee into? I don't know... May 7, 2008 - 1:09 AM
lagos The round thing is just a filter.
You can use any... May 7, 2008 - 11:32 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 9:49 PM |
