May 5, 2008 - 5:33 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
Hey guys, I'm looking into possibly turbo'ing the car a few months down the road. I read the FAQs, but I was confused about what parts I actually need. Here is what I came up with as far as parts:
New, lower mileage motor 3S-GTE oil pan and drain lines 3S-GTE 2 bar map sensor 3S-GTE Manifold/downpipe CT26 (twin entry) MK3 Supra N/A injectors MK3 Supra intercooler Intercooler piping SAFC Boost controller Boost gauge Oil pressure gauge Headgasket Now, here are the questions I had. Why must you use the twin entry CT-26? Does the single entry (aka Supra) CT-26 work? Is this because of the 3S-GTE manifold? If I bought an aftermarket 3S manifold, could I then use the Supra CT? I ask because I have access to a few of these. Also, what is needed concerning the oil and coolant lines? This is where I get confused. I would like this to the as budget of a build as possible, but at the same time be reliable. I would plan to run 6-8psi or so. -Matt |
May 5, 2008 - 8:26 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
The oil drain/ feed line you can get from other forums. You will need to cut the factory hard feed line and weld on a fitting so you can run a stainless steel line to your turbo.
The ct-26 turbo we all use is the dual entry turbo either from the alltrac or mr2 turbo. Why? Because it fits onto the turbo manifold which is dual outlet footing. Why we use those manifolds? Because it bolts right up to our head. If you want single entry the 1st gen 3sgte came single entry turbo with a single outlet manifold, but I read some where it won't fit on our head. It seems to me you want to cut on cost because the ct26 single entry is far cheaper. You gotta play to play buddy. -------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
May 5, 2008 - 8:50 PM
Enthusiast ![]() ![]() Joined Feb 7, '08 From Colorado Springs, CO Currently Offline Reputation: 0 (0%) |
QUOTE(GotToyota @ May 5, 2008 - 5:33 PM) [snapback]670876[/snapback] I would like this to the as budget of a build as possible, but at the same time be reliable. Reliable and budget??? Nah... If you're wanting to be safe and reliable, you better drop some money on it -------------------- |
May 5, 2008 - 9:12 PM
Like I said...
QUOTE(bccentaur3 @ May 5, 2008 - 8:26 PM) [snapback]670934[/snapback] You gotta play to play buddy. -------------------- 98 Celica gt red- totaled deer
May 5, 2008 - 9:27 PM
Enthusiast ![]() ![]() Joined May 23, '06 Currently Offline Reputation: 0 (0%) |
Dont you mean pay to play?
May 5, 2008 - 9:48 PM
LOL..... Yeah thats what I meant. I guess typing all these papers for finals has gotten me dislexic. How ever you spell it.
May 6, 2008 - 4:25 AM
fast, cheap, reliable.
pick any 2. -------------------- Former Team 5SFTE pro member ;)
May 6, 2008 - 5:19 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
QUOTE New, lower mileage motor 3S-GTE oil pan and drain lines 3S-GTE 2 bar map sensor 3S-GTE Manifold/downpipe CT26 (twin entry) MK3 Supra N/A injectors MK3 Supra intercooler Intercooler piping SAFC Boost controller Boost gauge Oil pressure gauge Headgasket dont forget the fuel pump dont need the head gasket if the "New, lower mileage motor" has a good one -------------------- ![]() |
May 6, 2008 - 8:06 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
QUOTE(presure2 @ May 6, 2008 - 4:25 AM) [snapback]671062[/snapback] fast, cheap, reliable. pick any 2. unfortunate for us though -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
May 6, 2008 - 9:42 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
go for the 460cc injectors from an RX7, (they're mentioned in one of the later replies to manny's thread) instead of the supra ones. also I'd pring for a front mount intercooler. The supra one is side mount, isn't it? you'll need a fuel pump. and some sort of intake, plus a cutom made exhaust. that's all I can think of right now.
-------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
May 6, 2008 - 10:17 AM
QUOTE(6strngs @ May 6, 2008 - 9:42 AM) [snapback]671100[/snapback] go for the 460cc injectors from an RX7, (they're mentioned in one of the later replies to manny's thread) instead of the supra ones. also I'd pring for a front mount intercooler. The supra one is side mount, isn't it? you'll need a fuel pump. and some sort of intake, plus a cutom made exhaust. that's all I can think of right now. The MK3 Supra one is front mounting, and would be just fine for a simple 6psi setup. I also realize that I would have to get an intake and a fuel pump, I just forgot to add them to the list. As far as exhaust, I think I'd use the stock one. I'd like to pass inspection as easily as possible, if I even could. I'm sure if I got a rock solid tune, it'd be a possibility. -Matt |
May 6, 2008 - 4:25 PM
QUOTE(GotToyota @ May 6, 2008 - 8:17 AM) [snapback]671104[/snapback] QUOTE(6strngs @ May 6, 2008 - 9:42 AM) [snapback]671100[/snapback] go for the 460cc injectors from an RX7, (they're mentioned in one of the later replies to manny's thread) instead of the supra ones. also I'd pring for a front mount intercooler. The supra one is side mount, isn't it? you'll need a fuel pump. and some sort of intake, plus a cutom made exhaust. that's all I can think of right now. The MK3 Supra one is front mounting, and would be just fine for a simple 6psi setup. I also realize that I would have to get an intake and a fuel pump, I just forgot to add them to the list. As far as exhaust, I think I'd use the stock one. I'd like to pass inspection as easily as possible, if I even could. I'm sure if I got a rock solid tune, it'd be a possibility. -Matt I don't know the laws in your state, but I've heard texas is as strict as california, so I doubt you'll be able to. I don't think it's legal to turbo a non-turbo car. but check the laws in your state first. as for exhaust, it's going to be super, super restrictive, plus it'll need to be modified to mate up to the downpipe anyway I think. -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
May 7, 2008 - 6:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
QUOTE(6strngs @ May 6, 2008 - 9:25 PM) [snapback]671229[/snapback] QUOTE(GotToyota @ May 6, 2008 - 8:17 AM) [snapback]671104[/snapback] QUOTE(6strngs @ May 6, 2008 - 9:42 AM) [snapback]671100[/snapback] go for the 460cc injectors from an RX7, (they're mentioned in one of the later replies to manny's thread) instead of the supra ones. also I'd pring for a front mount intercooler. The supra one is side mount, isn't it? you'll need a fuel pump. and some sort of intake, plus a cutom made exhaust. that's all I can think of right now. The MK3 Supra one is front mounting, and would be just fine for a simple 6psi setup. I also realize that I would have to get an intake and a fuel pump, I just forgot to add them to the list. As far as exhaust, I think I'd use the stock one. I'd like to pass inspection as easily as possible, if I even could. I'm sure if I got a rock solid tune, it'd be a possibility. -Matt I don't know the laws in your state, but I've heard texas is as strict as california, so I doubt you'll be able to. I don't think it's legal to turbo a non-turbo car. but check the laws in your state first. as for exhaust, it's going to be super, super restrictive, plus it'll need to be modified to mate up to the downpipe anyway I think. i know in s. texas that they dont even do EMISSIONS test. but i know you can have exhaust, intake.. all tht stuff. here its legal to turbo too. check local regulations though. talk to someone who will inspect your car -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
May 12, 2008 - 8:54 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Not everywhere in Tx
This post has been edited by DEATH: May 12, 2008 - 8:54 AM -------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
May 12, 2008 - 9:36 AM
well Houston air IS smog.. soo lol.
| Lo-Fi Version | Time is now: August 31st, 2026 - 8:43 PM |
