May 6, 2008 - 11:58 AM
Enthusiast ![]() Joined Feb 19, '08 From Missouri Currently Offline Reputation: 0 (0%) |
I changed my pads a few years ago and I just started hearing the wear sensor squeel. I only drive about 5000mi a year so I took the tire off to see what was up. Only one pad is worn down and the rest are still new. My question is, do I just need to bleed the brakes or is there more that I'm not seeing here? If I just need to bleed, do I bleed the three that aren't stopping or the one that is?
Thanks, Don |
airforceb2cc Abnormal Brake Wear May 6, 2008 - 11:58 AM
GriffGirl Sounds like you could possibly have an issue with ... May 6, 2008 - 12:07 PM
airforceb2cc QUOTE(GriffGirl @ May 6, 2008 - 12:0... May 6, 2008 - 12:54 PM
GriffGirl I think it sounds unlikely that you'd have air... May 6, 2008 - 1:37 PM
alltracman78 Something is probably frozen, either the caliper p... May 6, 2008 - 10:26 PM
Galcobar If you do have a frozen caliper, which seems likel... May 7, 2008 - 1:30 AM
airforceb2cc I got the new bracket in today and installed. I... May 7, 2008 - 1:24 PM
WannabeGT4 Wow. DeJaVu. I was replacing my pads the day befor... May 7, 2008 - 2:35 PM
airforceb2cc QUOTE(WannabeGT4 @ May 7, 2008 - 2:3... May 7, 2008 - 4:21 PM
WannabeGT4 QUOTE(airforceb2cc @ May 7, 2008 - 4... May 7, 2008 - 4:26 PM
airforceb2cc Very true...I'll be taking them off again soon... May 7, 2008 - 4:53 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 1st, 2026 - 7:05 PM |
