> FS 3SGTE ECU reprogrammed by TOMS
post May 7, 2008 - 7:52 PM
alltracman78
Joined Aug 9, '06
From Ma
Gen II 3SGTE 93 MR2 ECU
Reprogrammed by TOMS of Japan. Boost cut is raised to 22 PSI and redline is raised to 8000 RPMs. Fuel and timing maps are also advanced. Still programmed for 440cc inj.
This is a great power boost for those of you still on the stock ECU, and can be ran alone or with a piggyback. This let's you get rid of your FCD so you can safely run higher boost [to a point obviously].
This ECU works 100%, I had it running in my Alltrac for several years.
It's completely plug and play for 92/93 Alltracs, or swapped cars with those year ECUs. It will also work for a 90/91 version, but some wires will have to be repinned.
$400 shipped in the cont US. AK/HI I'll have to check shipping.
Outside of the US you will have to pay for shipping.
post May 7, 2008 - 9:09 PM
terqui
Joined May 23, '06
This is one of those rare once in a lifetime finds. I wish i just had a 3s to use it on frown.gif
post May 7, 2008 - 10:28 PM
_mikeE
Joined Sep 28, '07
From Toronto, ON
Damn, what a steal for whoever purchases this--btw, why are you selling it?
post May 8, 2008 - 8:23 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
if you still have in 2 weeks ill buy it from you
post May 8, 2008 - 8:25 PM
block
Joined Jul 27, '06
From Soda
damn if you still have it in july, ill buy it! but otherwise good luck bro...
Lo-Fi Version Time is now: July 30th, 2026 - 2:33 AM
