> toyota red coolant. 5/24 Changed my radiator..., WOOT, Woot
post May 9, 2008 - 6:57 AM
Well, i know red coolant is the prefered one. how do we mix it though?
I have no clue. Its supposed to be a 60/40 mix. Thats what they told me. Is this true.
Anyways, also about the KOYO oem radiator, it has two little lines on the bottom that i assume are for the automatic, not for the manual, so, they are plugged with two little rubber caps. Would that hold the pressure, should i use something else?
This post has been edited by njccmd2002: May 24, 2008 - 1:50 PM
- njccmd2002   toyota red coolant. 5/24 Changed my radiator...   May 9, 2008 - 6:57 AM
- - hurley97   The Super Long Life Coolant is prediluted to 50/50...   May 9, 2008 - 8:19 AM
- - playr158   you want to run as little coolant as possible to g...   May 9, 2008 - 8:22 AM
- - njccmd2002   the dealer always recommended the red colant, but ...   May 9, 2008 - 1:25 PM
- - Bitter   that atf cooler can be used as a turbo oil cooler ...   May 10, 2008 - 11:32 AM
- - malecrod   I have a question: it is true that if the red and ...   May 10, 2008 - 11:54 AM
- - Bitter   not good to mix regular green with other types, it...   May 10, 2008 - 3:47 PM
- - mrgt4   say no need to mix the red coolant, its already to...   May 10, 2008 - 7:43 PM
|- - njccmd2002   QUOTE (mrgt4 @ May 10, 2008 - 8:43 P...   May 10, 2008 - 7:50 PM
- - Silver94CelicaOwner   Toyota manufactures two different mixture coolants...   May 10, 2008 - 8:30 PM
|- - Insanity-74   QUOTE (Silver94CelicaOwner @ May 11, 2008 ...   May 11, 2008 - 4:02 AM
- - malecrod   Thanks everyone. I was concerned because I just c...   May 10, 2008 - 10:41 PM
- - lagos   Lots of different info going on here. I tested th...   May 11, 2008 - 10:10 AM
- - Silver94CelicaOwner   Yea the Toyota Red thats available in the states i...   May 11, 2008 - 10:33 AM
- - lagos   QUOTE (Silver94CelicaOwner @ May 11, 2008 ...   May 11, 2008 - 10:20 PM
- - playr158   lmao...ripped off water wetter + distilled water ...   May 12, 2008 - 5:53 AM
- - njccmd2002   well i did kind of a 60/40 dilution. But also hav...   May 24, 2008 - 1:52 PM
- - njccmd2002   here is the trash out and the new in.. and ...   May 25, 2008 - 3:03 PM
- - Bitter   you reused the hoses and clamps? those clamps WIL...   May 25, 2008 - 8:04 PM
- - njccmd2002   hoses are new, i know i need new clamps, forgot to...   May 25, 2008 - 8:22 PM
- - Bitter   as long as you know. glad you replaced the hoses...   May 26, 2008 - 10:58 AM
Lo-Fi Version Time is now: September 2nd, 2026 - 2:10 AM
