> FS/FT: 1995 Toyota Celica Turbo swapped 300hp, Buy ME or Trade For Me
post May 10, 2008 - 9:02 PM
cyb593
Joined Feb 22, '04
From USA
GOT VIDS ON YOUTUBE PM ME IF INTERESTED IN THE CAR!!
Will trade for a SUV, preferably 4runner. I need an SUV so cash $5000 obo or Trade equal or less plus cash.
1993 jdm toyota 3sgte with receipt from noyan motorsprts with 40k miles
1993 jdm st185 tranny with mr2 gear for fwd conversion
cusco 2 way lsd
Haltech e6x standalone ecu with sensors
tuned by NTO motorsports at 12 psi 296whp and 263ft lbs of torque
NTO custom wiring harness for 3sgte to haltech
all-trac/mr2 axles
custom tranny mounts
custom tubular manifold and reinforced (cracked, have factory turbo and manifold ready for install)
tial wastegate 38mm with 10 lb spring (factory is internally wastegated so wont need this if going back factory)
t3/t4 super 60 turbo (will be factory turbo with factory manifold when you install it)
NEW EXHAUST ( $700 for exhaust sounds good)
all stainless steel oil lines (one in the front is leaking)
brand new gasket set and toyota water pump
new toyota timimg belt
All haltech sensors and tapped water pump and intake manifold
walbro 255lph fuel pump
aeromotive fuel pressure regulator
stainless steel -6an fuel lines
srt custom intercooler piping welded 2.5 in
hks ssq blow off valve
MSD 6al ignition with blaster 2 coil
MSD spark plug wires
godspeed large instercooler
gauges : oil psi, water temp ,boost, tach (speedo doesnt work)
momo steering wheel and momo hub
NTO battery reloction kit in trunk
Jet flat black paint job,....not rattle can, but its flat black
one dent on quarter panel on drivers side and one on front fender nothing to major
The speedo doesnt work, needs a fuel injector resistor installed(will provide the part), and idle speed motor(have to idle the car for yourself at warm up. Wont run correctly till it gets above 150 water temp(due to no injector resistor) Has oil leak at the oil line. Got the exhaust put in for $700 I stopped driving it till oil leak is fixed but start it up once or twice a week. Also the windshield if leaking needs new seal. Needs wheels and tires. The wheels in the pictures do not come with the car. There are 2 steelies and 2 rims on the car now but need good tires. These wheels have started to dry up.
This post has been edited by cyb593: May 20, 2008 - 5:44 PM
Replies (1 - 12)
post May 11, 2008 - 2:22 PM
cyb593
Joined Feb 22, '04
From USA
bump
post May 11, 2008 - 2:25 PM
2slow2nervous
Joined Aug 25, '06
From HAMILTON NJ
would you be willing to part your turbo setup and tuned ecu for my stock 3sgte setup and cash?
post May 11, 2008 - 5:07 PM
cyb593
Joined Feb 22, '04
From USA
just trying to get rid of the whoel car no really part it. would take me forever to part it, i dont have that kind of time.
post May 11, 2008 - 8:13 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
hows the shifting?
post May 11, 2008 - 8:36 PM
SeverX13
Joined Dec 4, '07
From Northeast Pennsylvania
what year 4 runner?
post May 11, 2008 - 9:51 PM
cyb593
Joined Feb 22, '04
From USA
preferably 94 and up body in good condition and i dont want rust damage, also want either even trade or my car plus cash
QUOTE (SeverX13 @ May 12, 2008 - 2:36 AM) *
what year 4 runner?
post May 11, 2008 - 9:59 PM
cyb593
Joined Feb 22, '04
From USA
it shifts great!! Due to the transmission the nuetral is not dead center just slightly off to the right since the shifter cables are in a different spot then on an alltrac. This doesnt effect shifting or anything gears are just slighly to the right more than normal but shifts like a knife through butter.
This post has been edited by cyb593: May 11, 2008 - 9:59 PM
post May 11, 2008 - 10:03 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
wait, so what shifter cables are in there though>
post May 12, 2008 - 3:47 PM
cyb593
Joined Feb 22, '04
From USA
bumpity
post May 13, 2008 - 5:58 PM
cyb593
Joined Feb 22, '04
From USA
bump
post May 14, 2008 - 12:52 PM
cyb593
Joined Feb 22, '04
From USA
wesnesday bump
post May 20, 2008 - 5:43 PM
cyb593
Joined Feb 22, '04
From USA
bump
Lo-Fi Version Time is now: August 28th, 2026 - 3:31 AM
