> How much oil is too much, im about half a quart over
post May 12, 2008 - 4:41 PM
pepsiman
Joined Jun 3, '06
When i changed my oil the last time i overfilled it by about half a quart, this happend because much to my rage i spilled some so i overcompensated too much when i tried to put in a little over 4 quarts. The engine has been run for a few weeks like this, yesterday while the engine was warmed up i checked my oil and was shocked at how overfilled it was, i was wondering will this hurt anything? Thanks for the help
post May 12, 2008 - 5:41 PM
Remy
Joined Jan 25, '06
From MN
If you overfilled (depends how much) your motor with oil my advice to you is drain it and start over again it. Yes is can cause engine damage when you overfill the crankcase with oil, it'll foam up and cause problems like throw a rod through your block or worse a seized motor.
"To Protect And To Serve The Wealthy" -POLICE
post May 12, 2008 - 5:55 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
^ I totally agree. You could do irreparable damage by running your engine with too much oil in it. Drain some of it out before you screw up your gaskets/valve seals/whatever it is that gets ruined by this (I forget, but I know it's not good).
post May 12, 2008 - 6:50 PM
SilvertopST
Joined May 8, '08
From Marietta, Ga
it may be tedious, but just drain a little bit out, check it again, and repeat until it is filled to the full line.
post May 12, 2008 - 7:05 PM
95st-celica
Joined Mar 29, '07
From Philly
QUOTE (SilvertopST @ May 12, 2008 - 7:50 PM) *
x2
1988 Dodge Aries K (sold)
post May 12, 2008 - 7:10 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
It is actually ok to be up to a quart over. It is recommended, especially when you take many sharp turns.
-Matt
post May 12, 2008 - 8:28 PM
pepsiman
Joined Jun 3, '06
alright guys thanks for all the replies, so is half a quart (roughly) over enough to do all that? If it is ill drain it alittle tommrow shouldnt be too big of a deal
post May 12, 2008 - 8:59 PM
Remy
Joined Jan 25, '06
From MN
QUOTE (pepsiman @ May 12, 2008 - 8:28 PM) *
It'll be worse if you have a high mileage engine as all the seals are probably worn if not leaking already. My oil is always at 3/4 you never want too low or high. wink.gif
post May 12, 2008 - 10:32 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yeah, you ever take off your oil pan? if so you'll see that the baffle is right about at the full line on your dip stick, and when you remove the baffle you'll see the crank sits pretty much half an inch over that. and if i recall correctly the whole length between your full to empty marks it one qt. so that'll give you an idea of how much it is over and how deep your crank is sitting in oil, foaming it up causing all kinda of issues
post May 12, 2008 - 10:53 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
1/2 quart over is not desirable, but it wont be the death of your engine either.
post May 13, 2008 - 11:06 AM
pepsiman
Joined Jun 3, '06
I drained it a little, drether be safe than sorry my car dont seem to burn oil (my old celica burned some) so i figured it would be best to be on the safe side.
post May 13, 2008 - 11:24 AM
racingfong24
Joined Mar 9, '08
From Cottage Grove, MN
QUOTE (pepsiman @ May 12, 2008 - 4:41 PM) *
you dont want to check your engine oil while the engine is running. if you do it will always read high on your dip stick because the oil is being pumped around in the engine and that can cause a miss read if you check it. you have to let it sit for at least a few min (not 1 min but 5-10 mins) untill you can properly check it. if you drained it while using that reading you took with the engine running, you might be to low now.
just wanna like you know
post May 13, 2008 - 2:37 PM
pepsiman
Joined Jun 3, '06
lol it had been settin for a hour or 2 but was still pretty warm to the touch when i checked it
a few minutes ago i let her run for a minute or 2 then let it set and checked it again and its right on biggrin.gif
Lo-Fi Version Time is now: August 27th, 2026 - 1:02 AM
