> rwd...yes another thread, new option?
post May 13, 2008 - 8:29 AM
Ok, so i'm the crazy mod whore. I like things that waste money and are more than unfeasible.
practical discussion:
for a RWD setup. who has experience with IS300s.
I have been thinking that their rear end might jus work.
$250 for a cross memeber
$300 for a diff
$100 for a drive shaft
then you need control arms, ect. but you get a rear end brand new for lets say under a grand including everything
size/dimensions/shape issues?
they have the toyota typical 3-point strut hats so they potentially up top could slide right in (as if that was a major obstacle laugh.gif )
discuss...
This post has been edited by playr158: May 13, 2008 - 8:30 AM
3 Pages V   1 2 3 >
Replies (1 - 19)
post May 13, 2008 - 8:57 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
the IS300 i believe is about the same width of our car, i would really like to see this tried
what engine would you use?
how is your RHD conversion going?
post May 13, 2008 - 9:01 AM
RHD has been completed for several months.
post May 13, 2008 - 12:00 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
QUOTE (stephen_lee @ May 13, 2008 - 9:57 AM) *
black top beams
Isnt the wheelbase on the IS300 longer then the Celica, the drive shaft will be to long?
honestly, i think the TRUE way to go about RWD, is st205 rear end, and some how, disable the FWD on the AWD tranny. (...idk how to do it, or if its possible, but IS300 parts sounds like a dangerous path)
edit: IS300 Wheel base: 105.1 in. (2669.54mm) 6gc: 1060mm (41.732283465 in.) i understand its not a direct traslation between wheelbase and driveshaft, but...distance is distance.
This post has been edited by devilsden97: May 13, 2008 - 12:06 PM
Kawi Love
post May 13, 2008 - 12:01 PM
QUOTE (devilsden97 @ May 13, 2008 - 1:00 PM) *
black top beams
you can't just disable part of a transmission. and I don't think the ST205 rear end can withstand the full force of a motor (i think its roughly 60% from the factory?)
post May 13, 2008 - 12:13 PM
devilsden97
Joined Jun 13, '05
So what engine and tranny do u plan to use? (i dont recall the tranny for RWD 3sgte, i believe there is one tho)
Kawi Love
post May 13, 2008 - 12:52 PM
don't know what version of the 3s motor i will use...IS300 rear = 3sge black top, other = 3rd gen 3sgte
post May 13, 2008 - 12:59 PM
devilsden97
Joined Jun 13, '05
QUOTE (playr158 @ May 13, 2008 - 1:52 PM) *
ah right. 3sge rwd tranny from a black top??? is that what you're implying? sounds logical, but ALOT of difficultites to over come with the rear suspension work alone.
edit: grammar
This post has been edited by devilsden97: May 13, 2008 - 12:59 PM
Kawi Love
post May 13, 2008 - 2:44 PM
trd-celica
Joined Mar 17, '08
From Manchester,N.H
how about mr2 tranny i've heard they put it in 3sgte swaps if that the engine your going to use
post May 13, 2008 - 2:45 PM
devilsden97
Joined Jun 13, '05
QUOTE (trd-celica @ May 13, 2008 - 3:44 PM) *
MR2 is layed out like a celica...in reverse.
what i mean is that the Mr2 has no rear diff. its very similar to a FWD car, because the motor is in the back.
This post has been edited by devilsden97: May 13, 2008 - 2:48 PM
Kawi Love
post May 13, 2008 - 3:16 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE (devilsden97 @ May 13, 2008 - 8:45 PM) *
MR2 is layed out like a celica...in reverse... because the motor is in the back.
So do that, then wink.gif You could get a lot of luggage under the Celica bonnet if the engine wasn't there biggrin.gif
post May 13, 2008 - 3:22 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Who says you need to use a Toyota rear end. Why not look into a domestic rear end? Anyway you look at this project you are doing everything custom. There are a million more parts that are interchangeable & cheaper from domestic vehicles.
Sticking a wider rear axle in the car and widening out the rear quarter panels would be very cool. This would also give you that RWD look.
If I were you, and I wanted to retain the look of a 6th gen. I buy and AE86 swap the body panels from the 6th gen, swap in a 3sgte, call it a day.
good luck
I will return one day.
post May 13, 2008 - 3:39 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
im with jeff.
you could prolly get away with a 3s swap and is300 trans, but you might as well go for a more powerful starting engine. why not stick a v8 in there, and bui.d the trans/driveshaft/rear from a hot rod recipe.
if people can replicate a cobra for under 30k, why ouldnt you replicate at least the trans/rear end options for less than say 3k?
imagine how sick it would look like jeff said with the rear quarter panels widened out by like 4 inches, and a nice bump in the hood molded in that's raised by like 6 inches.
then down the road you can always sc that engine and be making weel over 600 hp for about the same as you could in getting the 3s to 400
post May 13, 2008 - 5:11 PM
don't want to put domestic parts on an import.
attempting to stick to all toyota origin parts
hot rods and road course racing don't go together. IS300 = independant rear
plus if you use a blacktop beams its already matched to the IS300 rear in terms of gearing.
Domestic parts you have to start looking more into correct gear ratios, more custom fabrication and such.
my project actually has very little custom pieces that are completely distinct from anything else.
the blacktop is also a great NA road course motor (you don't need a billion and 1 horsepower) the ~200 some odd hp it produces is good + modifications it should be a great motor to use.
its not just about big hp #s, its about purpose building
and mentioning a V8 = retarded
This post has been edited by playr158: May 13, 2008 - 5:15 PM
post May 13, 2008 - 7:16 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
BANNED. for life, you moron.
post May 13, 2008 - 9:47 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
cant you do the same way subarus go rwd by doin something to the tranny, like weld shut the part where the front axles go??? or im just imagining something...........
post May 13, 2008 - 10:06 PM
JDM_Factory
Joined Mar 27, '08
From Fort Worth, TX
why not stay away from 4 bangers and go with a VZ mr MZ v6 motors, better torque and you're able to twin turbo them. Also parts are cheaper on these, since they are available everywhere. I just finish my 3vz swap on customer mr2 and I have to say it's a whole new story. I'm already planning to take out my 3s and put a 3mz instead.
I don't know how you're going to fabricate to have the RWD tranny to fit in there, but good luck!
This post has been edited by JDM_Factory: May 13, 2008 - 10:06 PM
post May 13, 2008 - 10:14 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
removed comment due to pure stupidity and me not thinking clearly when i typed it...
This post has been edited by cjh4l22: May 16, 2008 - 10:10 AM
post May 13, 2008 - 10:16 PM
QUOTE (JDM_Factory @ May 13, 2008 - 11:06 PM) *
cause i can achieve the same power goals with a smaller motor?
i would use a 3sgte cause its fully plug and play for my car
or a blacktop 3sge because its one of the best NA motors (plus full drivetrain available)
road course racing major tq numbers are not needed...3sge blacktop isn't a TQ motor anyways.
3sgte single turbo will be more efficient. 3sgte power goal is roughly ~500whp pump
and FYI 1 of a kind doesn't win races, function wins races
as for fabrication....tranny tunnel = cut + weld !? they aren't terribly difficult to fabricate
The whole concept behind the use of the IS300/RS200 rear end is that its still toyota, looks to be fairly similar to the ST205 rear, and has the correct gear ratios to be compatible with the black top 3sge + 6spd transmission. Gear ratio & rear diff properties being the major pros.
This post has been edited by playr158: May 13, 2008 - 10:20 PM
post May 13, 2008 - 10:25 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
QUOTE (playr158 @ May 13, 2008 - 11:16 PM) *
hey i didn't think so. but with all the odd suggestions (v8? seriously..) thought i'd throw it out there..
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: July 29th, 2026 - 12:26 AM
