May 13, 2008 - 11:14 PM
Enthusiast ![]() ![]() ![]() Joined Aug 19, '07 From Farmington, MI Currently Offline Reputation: 7 (100%) |
Hi, how do u correct the tps, basically make it perfect or so what.., any key things need to set it, cause i believe mine might be off be a little
May 13, 2008 - 11:29 PM
Ive done mine before.
You need a multimeter and feeler gauges. Check the bgb, it has specific instructions on what to do. This post has been edited by lagos: May 13, 2008 - 11:29 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 17, 2008 - 11:50 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
takes like 15-20 mins piece of cake.
May 18, 2008 - 6:22 PM
i checked the bgb guide, it is kinda confusing, so basically i am setting it when i get ohms from the contact point?
May 22, 2008 - 9:56 AM
anyone, what ohms are u getting when u touch the bottom 2 terminals, my buddies was getting around 30? could anyone check, cause the bgb guide is hard to understand
May 22, 2008 - 11:10 AM
you need to set it with feeler gauges.
May 22, 2008 - 12:24 PM
umm i dunno what those are, all i have been using is a fluke tester thingy
| Lo-Fi Version | Time is now: May 15th, 2026 - 8:27 PM |
