May 14, 2008 - 12:01 PM
Enthusiast ![]() Joined Mar 18, '08 From Colorado Springs, CO Currently Offline Reputation: 0 (0%) |
I did what it says in the how to aritcles but i cant get it to flash any codes, Connected the te1 to the E1 with paper clip and nothing happened. Followed the instructions right so if any one can help that would be appreciated. thanks!
edit: please check down several posts, i have explained my new problem and need help with that. This post has been edited by jt_3212: May 14, 2008 - 11:12 PM |
jt_3212 cant get engine light to flash May 14, 2008 - 12:01 PM
devilsden97 are u using a tiny paper clip? get a larger one. s... May 14, 2008 - 12:19 PM
jt_3212 oh really, that blows, is there still away to do i... May 14, 2008 - 12:59 PM
purplegt4 they should scan it for free at your local car par... May 14, 2008 - 1:07 PM
devilsden97 ODBII code reader, plug it into the diagnostic (wo... May 14, 2008 - 1:28 PM
GriffGirl Autozone will scan it for free! May 14, 2008 - 1:50 PM
jt_3212 ok cool i'll keep that in mind. but the crazie... May 14, 2008 - 11:05 PM
blackbullet Your check engine light is off but run it for a wh... May 15, 2008 - 12:57 AM
jt_3212 ok yeah that sounds good. i'lll try that, seem... May 15, 2008 - 12:33 PM
GriffGirl Check your ground wires, it sounds like you have a... May 15, 2008 - 2:41 PM
jt_3212 well i got my alternator checked and it said it wa... May 15, 2008 - 5:29 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 11:25 AM |
