May 15, 2008 - 2:05 PM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
Its 3am in Oz and Im stuck with this gay question:
I know that sin(t) = 1/(s^2 +1) and -t= -1/(s^2) ---> thus = -1/(s^2 +1)^2 but where the fin 2s coming from?? I need a rest. -------------------- ![]() 98% completion --- aaRon |
May 15, 2008 - 2:48 PM
![]() Enthusiast ![]() ![]() ![]() Joined Nov 1, '07 From Santa Barbara, CA Currently Offline Reputation: 2 (100%) |
from what I remember you shouldn't have the variable 's' on top since its a sin function. The 's' comes in when you're using cos. Are you sure you came to that equation correctly? maybe your mistake is earlier. Gl and get some sleep
May 15, 2008 - 2:59 PM
ugh.
May 15, 2008 - 4:14 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 26, '07 From riverside,CA Currently Offline Reputation: 0 (0%) |
im asian
and i cant figure that out -------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
May 15, 2008 - 4:37 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '07 From Washington Currently Offline Reputation: 9 (100%) |
Man, I havn't done sin,cos, or tan since HS..sorry can't help you w/ that.
May 15, 2008 - 4:45 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
did you figure it out yet?
if not i can break out my old books n give er a whirl. i used to be good at this stuff like 3 years ago -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
May 15, 2008 - 4:51 PM
May 15, 2008 - 8:16 PM
from what I remember you shouldn't have the variable 's' on top since its a sin function. The 's' comes in when you're using cos. Are you sure you came to that equation correctly? maybe your mistake is earlier. Gl and get some sleep Actually I need to prove how to get from that to -tsint. But its the Inverse Laplace Transform of Derivatives. -------------------- ![]() 98% completion --- aaRon |
May 15, 2008 - 10:01 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
Well... I think you take the Laplace of both sides... should get ride of the Laplace on the left... then you have L (-t sin (t) ) which, after trig identities should expand into something more manageable....
-------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
May 15, 2008 - 10:15 PM
Yea thats the method to use. nice work qatar
Ok my turn, i've got this assignment due at 5 tomorrow if anyone wants to do it for me. http://www.engr.ucsb.edu/~me151c/Hw5.pdf back to work |
May 15, 2008 - 11:20 PM
This is how far I got... I started off with the definition of Leplace, used Integration By Parts, used an Exponential Integration, Used an Euler Identity to reduce the equation...
The only hitch, and it is a big one... I end up with 2t on the top not 2s...,and that t goes to infinity..... maybe I screwed something up somewhere dunno... its been like 5 years since Calc 3.
May 15, 2008 - 11:27 PM
I dunno... maybe the integration by parts needs to be done from 0 -> inf as well?
not likely though... -------------------- -Mike
May 15, 2008 - 11:31 PM
Yea thats the method to use. nice work qatar Ok my turn, i've got this assignment due at 5 tomorrow if anyone wants to do it for me. http://www.engr.ucsb.edu/~me151c/Hw5.pdf back to work <Shudders> this is why I am an EE <shudders> -------------------- -Mike
May 15, 2008 - 11:33 PM
The answer is C.
May 16, 2008 - 7:41 AM
@Lagos,
Where were you before I spent an hour on this? -------------------- -Mike
May 16, 2008 - 10:09 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
YOUR error is simple
if your demoninator is SUPPOSED to be (s²+1)², you need to have (s²-1)(s²+1) on the bottom. you are doing (s²+1)(s²) which gives s^4+s². . . if u still need this solved lemme know, i'll have to go back to the identities, i haven't taken differential equations for 2 years. but i just graduated!@!!!! Commencement tomorrow, my birthday today! w00t -------------------- ![]() |
May 16, 2008 - 10:25 AM
just skimmed the 2nd search result till i saw Sin.
page 13 http://www.math.utah.edu/~gustafso/2250LaplaceTheory.pdf has your exact solutions, tsinat = 2sa/(s²+a²)² -------------------- ![]() |
May 16, 2008 - 10:41 AM
Ya but the work, which is what he has to proved, is left as an exercise.....
though im guessing it is identical to a, where they use t*cost(at) Bah, I'm too old for this ****... -------------------- -Mike
May 16, 2008 - 10:58 AM
Ahhh I know what Im forgetting now...
Cheers for all da help...now i know where to go when im stuck! -------------------- ![]() 98% completion --- aaRon |
May 16, 2008 - 11:20 AM
nvm, followed it.
you just did the top deriv 2nd, so the minus was at the wrong spot, i usually do substitution for stuff now This post has been edited by Consynx: May 16, 2008 - 11:27 AM -------------------- ![]() |
| Lo-Fi Version | Time is now: May 20th, 2026 - 10:25 AM |
