> i need help wiring up my car!!!!Plzzzz, it wont star and this wires rea missing or i cant find them
post May 20, 2008 - 12:13 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
ok so i just got my wiring back from tweak. i started to plug evrything together and i notice that am left with a few grounds that forgot where they go and a few connectors that i cant seem to find where to connect to . also i tried to connect my battery together and i cant find where to conect the positve side of the battery! well i took some pics of the wiring any help will be apraciated. oh and i found that i need a new starter where would i be able to buy one autozone? also i have celica gt tranny on a 3sgte do ineed to be using the starter from the gt or from the alltrac?
GROUNDS
CONNECTIONS
NEGATIVE
POSITVE ???
post May 20, 2008 - 1:11 AM
azian_advanced
Joined Apr 18, '05
From Calgary
that must be a negative.
post May 20, 2008 - 10:32 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
anyone plz am trying to get this thing running
post May 20, 2008 - 1:43 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
First pic is the EFI noise filter, that plugs into your harness somewhere and you just bolt it down wherever.
Second pic looks like maybe the EGT sensor from the cat? You don't need that.
Third pic is your resistor pack for the injectors, you will use the 5-wire plug that goes to the harness, the smaller 2-wire resistor pack you don't use.
Fourth pic I have no idea (need wire colors)
Fifth pic is for a ground, you may or may not have the matching connector, not a big deal but make sure that you have a least a couple grounds between the engine and chassis.
Sixth pic does look like the negative cable.
Seventh pic is the positive power into the harness, that needs to go to your positive battery terminal lug along with the main cable down to the starter. (As I recall you didn't send us the positive cable).
If you need more help just give me a call at 404-474-4573 or email.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post May 20, 2008 - 1:59 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
once again dr.tweak to save the day!! laugh.gif yeah trust me he know what he is talking about..helped me out with my 3rd gen harness..good luck
This post has been edited by RUNNIN-LOW: May 20, 2008 - 1:59 PM
Lo-Fi Version Time is now: September 12th, 2026 - 12:54 AM
