> inside of my 17's rub, what the heck!!
post May 20, 2008 - 11:51 AM
NickJames
Joined Oct 5, '05
From Milwaukee
I pulled off my front rims last fall and noticed that the inside of my tire was rubbed real bad...lucky I took them off when I did!! problem is..I can't see any absolute tell tale signs of where its rubbing, the exact same parts of my tire on both sides, any help would be greatly appreciated cuz I want to buy new tires and put them on soon
post May 20, 2008 - 12:38 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Get some spacers.
**** Photobucket
post May 20, 2008 - 3:25 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
what do you mean by "inside of my tire"? Inside on the tread? Inside on the sidewall?
post May 20, 2008 - 4:15 PM
95CelicaST
Joined Feb 5, '05
I think he means that the sidewall is rubbing on the strut/spring, meaning his wheels have an offset of ~+45 or more
Or he's got crazy negative camber and the inside tread is rubbing the strut.
This post has been edited by 95CelicaST: May 20, 2008 - 4:15 PM
**** Photobucket
post May 20, 2008 - 4:26 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
Model: ADR SOKUDO
Bolt Pattern: 5x100/5x114.3
Offset: +42
Color: Gold W/Polished Lip
Sounds like a alignment problem
This post has been edited by Daftboy: May 20, 2008 - 4:30 PM
post May 26, 2008 - 4:39 PM
NickJames
Joined Oct 5, '05
From Milwaukee
nope...not alignment...its rubing on the corner where the side wall and the tread are, almost literally rite on the corner and its seems to be about a 90 degree indent from whatever its rubbing on
post May 27, 2008 - 9:56 AM
95CelicaST
Joined Feb 5, '05
If it's right on the corner it is you camber. You've got too much negative camber. You need to go get an alignment/ buy a camber kit.
**** Photobucket
post May 28, 2008 - 9:07 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
i had a slight rubbing problem awhile back and it could be noticed on places where the metal was clean or you could see small cuts in the outside tread on the tire... def take it to a shop and see what can be fixed
post Jun 3, 2008 - 8:58 AM
naxxal
Joined Apr 26, '07
From Fort Lauderdale, FL
QUOTE (tim86 @ May 28, 2008 - 2:07 PM) *
My celica just had one of the tires blown on the highway, i looked at it and could not figure out what was wrong, than i took off all four wheels and noticed ALL 4 sidewall of the tires rub on strut and shock bars. Since i bought my car from my buddy who didnt take very good care of it i realized i need to replace some major parts. By the way the tires are 215/45-17. Someone mentioned spacers are recommended, i may replace all four tires, lower it, redo alignment, and brakes, hoping to get it in better shape.
post Jun 19, 2008 - 3:17 AM
trdproven
Joined Aug 2, '05
From Guam
For 17's i think you have too high of an offset.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 27th, 2026 - 9:25 PM
