> So I Installed the rear Eibach Camber kits, Whats the OEM Camber in the rear?
post Jun 1, 2008 - 2:29 PM
Im pleased with the results so far. Putting these suckers is a PITA.
Pulled the upper bolt out with this...
then inserted the kit and aligned it where i wanted....
i had to untorque the bottom one, so that i can adjust it. I just guesstimated by moving this line to match the struts. this is where the lines did not meet. in the Above pic I had them meet. Not very scientific... cwm13.gif then torqued everything back together...
What is the camber specs? I will get it aligned, but just wanted to know? the two front tires are next..
This post has been edited by njccmd2002: Jun 1, 2008 - 2:33 PM
post Jun 1, 2008 - 2:36 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Looks good. I can't wait to get mine done all around.
-Matt
post Aug 7, 2008 - 8:12 PM
i got around to the front. and after that i got it aligned.
much better handling!!!!!!!!!!! i did a very good job doing the camber, but messed up the toe with the kit, dunno why... anyways
it had to be aligned !
This post has been edited by njccmd2002: Aug 7, 2008 - 8:13 PM
post Dec 12, 2008 - 7:37 PM
Jaws4God
Joined Mar 27, '04
I just put mine on this evening, going to get new tires and then alignment tomorrow and pray that everything is perfect and no more crappy wear.. smile.gif
BTW, how do you adjust them? it seemed like as I would tighten they would adjust all the way out but then stop? I figured then'd keep spinning around and you'd just come back again if you went to far, you know what I mean?
(so like as you spin they'd adjust out...then back in... then back out... until you tighten the nut..
Big props to the write up, I was hoping to find something like this and thanks to 6gc.net the guys/girls had it covered. smile.gif
This post has been edited by Jaws4God: Dec 12, 2008 - 7:39 PM
post Dec 13, 2008 - 6:33 PM
double ratchets and sockets. the metal needs to point out.
post Dec 14, 2008 - 5:32 PM
97celiman
Joined May 22, '08
From dallas texas
so i dont understand what these do...adjust the stock camber?
what is the improvement? i understand handling but what do these do that the stocks dont?
post Dec 14, 2008 - 5:37 PM
i lowered my car. thats the difference. my camber got screwed when i lowered. Hence i had to correct. Nobody would align until i got the kits.
post Dec 14, 2008 - 5:42 PM
manphibian
Joined Oct 13, '06
From UK
Good job. That all looks soo clean! Do they not salt the roads there in winter?
post Dec 14, 2008 - 6:56 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
^hes in Georga... its next to florida. there "unlucky" if they get snow... 1/8" puts them into a frenzy and no one goes out.
edit: spelling counts
This post has been edited by devilsden97: Dec 14, 2008 - 6:56 PM
Kawi Love
post Dec 14, 2008 - 8:26 PM
97celiman
Joined May 22, '08
From dallas texas
ahhh gotcha...so it makes it easier for whichever shop to align a lowered car with that on there?
post Dec 14, 2008 - 9:37 PM
some have lowered a car with no problems. IDK why my car had problems, but that is fixed
Lo-Fi Version Time is now: August 31st, 2026 - 10:43 PM
