Jun 10, 2008 - 10:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Hey guys, I'm in the middle of a 2nd gen 3sgte swap. I installed the stage 4 competition clutch with my factory s54 tranny. I'm am not done with the swap yet, but the motor is in. When I push down on the clutch pedal it just drops right to the ground. It won't spring back. Did I do something wrong? WHat can I do to solve this issue? And when I look at the clutch cylinder it doesn't move.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
bccentaur3 swap issues Jun 10, 2008 - 10:58 PM
Havok1997GT did you drain the fluid at anytime? Jun 10, 2008 - 11:12 PM
bccentaur3 no not the brake fluid. I drained oil, gear oil, a... Jun 10, 2008 - 11:13 PM
Havok1997GT You sure its still sealed up? like have you check... Jun 10, 2008 - 11:14 PM
stephen_lee you hooked up the hydrolic lines, right?
i'd c... Jun 10, 2008 - 11:14 PM
bccentaur3 Everything clutch related is hooked up. So you... Jun 10, 2008 - 11:34 PM
lagos QUOTE (bccentaur3 @ Jun 11, 2008 - 12... Jun 10, 2008 - 11:49 PM
bccentaur3 Bleed all of it out? Jun 10, 2008 - 11:51 PM
stephen_lee no! just untill there are no bubbles coming ou... Jun 10, 2008 - 11:54 PM
Smaay is it possible that the throw out bearing forks ca... Jun 11, 2008 - 2:42 PM
Batman722 first bleed the clutch line at the slave on the tr... Jun 11, 2008 - 4:00 PM
bccentaur3 alright I bled it, but I don't think I did eno... Jun 11, 2008 - 6:45 PM
Havok1997GT its not a funny thing to do. its pretty hard to d... Jun 11, 2008 - 8:34 PM
bccentaur3 What do I need connected to crank the car over? Fo... Jun 11, 2008 - 11:03 PM
soulshadow QUOTE (bccentaur3 @ Jun 12, 2008 - 12... Jun 11, 2008 - 11:09 PM
Havok1997GT i think there is a sensor in the Clutch pedal or c... Jun 11, 2008 - 11:07 PM
bccentaur3 And how the hell do you extend the throttle cable?... Jun 11, 2008 - 11:08 PM
bccentaur3 okay. How many grounds do we have? I know 2 coming... Jun 11, 2008 - 11:12 PM
Havok1997GT at this point i probably not being very helpful, b... Jun 11, 2008 - 11:21 PM
Havok1997GT ok. i was kinda looking around in the User guide t... Jun 11, 2008 - 11:39 PM
lagos QUOTE (bccentaur3 @ Jun 11, 2008 - 7... Jun 12, 2008 - 12:03 AM
stephen_lee when i bled my lines, i used the aerator hoses fro... Jun 12, 2008 - 12:09 AM
bccentaur3 See the problem is my brake fluid is filled with d... Jun 12, 2008 - 10:12 PM
scooterman when i did my clutch i messed up and had the slave... Jun 12, 2008 - 10:27 PM
malecrod Yeah, I would flush the entire system clear of the... Jun 12, 2008 - 10:37 PM
scothaniel I've had good luck with taking throttle cables... Jun 13, 2008 - 3:04 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 20th, 2026 - 9:06 AM |
