Jun 12, 2008 - 12:34 PM
Enthusiast ![]() ![]() Joined Jun 10, '08 From Virginia beach Currently Offline Reputation: 8 (100%) |
Hey, so my 94 St is havin a small electrical issue. My Open Door light stays on 24/7. Even with car off and both doors shut. I checked both sensors and did everything I can to stop it...but the light stays on. Is there any way to override this. Possible a wire to cut or a fuse to pull?
Thanks guys -------------------- |
d0w0rkS0n Door Sensor Jun 12, 2008 - 12:34 PM
S2CELLY Did you check the boot aswell. Or there is a switc... Jun 12, 2008 - 12:48 PM
stetsonaw this wouldn't solve the problem, but you can s... Jun 13, 2008 - 7:17 AM
njccmd2002 probably your sensor/switch does not work anymore.... Jun 13, 2008 - 9:21 AM
lubu The sensors are just momentary switches, a simple ... Jun 13, 2008 - 10:00 AM
6gsillyca Take your sensor apart, and clean the contacts wit... Jun 13, 2008 - 11:59 AM
lubu QUOTE (6gsillyca @ Jun 14, 2008 - 12... Jun 13, 2008 - 12:09 PM
6gsillyca Oops, my bad. I misread his post.
He should still... Jun 13, 2008 - 12:56 PM
97Celica There is a simple fix for this but it's danger... Jun 24, 2008 - 6:56 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 9th, 2026 - 9:59 AM |
