> starting issues, any of you electrical guys have any ideas?
post Jun 21, 2008 - 6:03 AM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
alright, so I had my viper alarm installed about 2 years ago. since then, I havent touched my tilt wheel (just never had to).
Now the other night, I got in my car and for one reason or another, I moved the tilt and heard a slight crunching in the movement.
so i get in, start the car, and when I turn on the headlights, the car turns off. Now im getting nothing, but my oil light, my battery light and my check engine light are lit n my dash, nothing else. No dome lights, nothing.
So i check fuses, fine. Then i remember i have my code reader in the trunk, so I take it out and as soon as i plug it in, all my interior lights turn on and the car starts.
now i find the car will not stay started unless i have this code reader plugged in!
anyone?
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Jun 21, 2008 - 6:12 AM
stevest202
Joined Oct 28, '07
From epworth uk
have you checked to see what was crunching thinking it might of damaged something maybe alarm or wiring shorting due to damaged partsbeing broken by this crunching sound
post Jun 21, 2008 - 11:16 AM
nightryder
Joined Sep 29, '05
im going to pull it all apart today, i just thought it was so weird that maybe someone could shed some light on it for me.
oh and when the car turns on without the code reader plugged in, it only stays running for about 3 seconds, then it shuts off.
post Jun 22, 2008 - 1:21 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
mabye u broke a wire and when the code reader is somehow connecting it...
BANNED. for life, you moron.
post Jun 25, 2008 - 4:52 PM
nightryder
Joined Sep 29, '05
i think i may have figured it out....
so if i had severed a ground wire , that would disengage the ignition.
now when i plug in the code reader, because of the nature of the reader, it grounds the ignition to the obdII scanner.
i guess now all i have to do is find that ground?
sound reasonable?
post Jun 29, 2008 - 4:25 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Sounds like your alarm wasn't installed with attention to detail.
Lo-Fi Version Time is now: August 4th, 2026 - 2:12 PM
