Jun 24, 2008 - 1:18 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 10, '06 From Knoxville, TN Currently Offline Reputation: 8 (100%) |
![]() I need the part numbers for these bolt clips & bolts. I figure they come as a set (one bolt clip and one bolt). There are five of them under the front bumper lip (See Picture). I thought I found the number on a diagram but the diagram was so small I could not make the number out. Thanks SeverX13 for the lower cover and the pic. If you have these as spares I will gladly buy them off of you. Any help would be greatly appreciated! Thanks -------------------- ![]() |
Jun 24, 2008 - 2:13 PM
Enthusiast ![]() Joined May 20, '06 From Netherlands Currently Offline Reputation: 1 (100%) |
Just bought these myself:
Clips underneath frontbumper (5x) 90179-06185 Bolts underneath frontbumper (5x) 90119-06355 -------------------- |
Jun 24, 2008 - 2:21 PM
Just bought these myself: Clips underneath frontbumper (5x) 90179-06185 Bolts underneath frontbumper (5x) 90119-06355 WOW!! Now that is AWESOME!! How much did they cost you if you don't mind? You don't happen to know the part number for the bolts that mount to the rear of the lower plastic pc to the bottom of the radiatior support do you? This post has been edited by ETNRIDER: Jun 24, 2008 - 2:24 PM -------------------- ![]() |
Jun 24, 2008 - 2:37 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
i just wired mine on,half of the plastics are sitting on the ground next to the house,my chassis is road hardened
-------------------- BANNED. for life, you moron.
Jun 25, 2008 - 11:58 AM
Does anyone happen to know the part number for the bolts that mount to the rear of the lower plastic pc to the bottom of the radiatior support do you? I think they are just 10mm bolts but If I could get a part number for them I would just buy them from Toyota.
Jun 25, 2008 - 4:43 PM
Those are exactly the same bolts as I mentioned earlier:
Bolts underneath frontbumper / undercover (4x) 90119-06355 So for the entire small undercover that's attached to the frontbumper and the crossmember, you'll need 9 bolts. Bolts are about 1 dollar a piece and the clips are about 2.50 dollar a piece. -------------------- |
| Lo-Fi Version | Time is now: July 12th, 2026 - 2:16 AM |
