Jun 27, 2008 - 10:58 PM
Enthusiast Joined Jun 8, '08 From LR, AR Currently Offline Reputation: 0 (0%) |
I need to replace my CV axles. Actually, the boots are bad, and the joints seem fine, but I'm afraid the task of taking apart the joints to replace the boots will be more than I want to do. So i picked up some CV axles from napa last weekend. I had the car up on the lift with the outer joint disconnected from the hub, and I couldn't separate the inner joint from the tranny! I tried prying on the tulip, like illustrated in the BGB, but to no avail. Also, prying against the tranny seems like a bad idea. Anyone have any hints as to how to get that thing out? I only tried the drivers side and failed, so i didn't even attempt the passenger side.....
BTW, the dealership wants $580 to replace the boots -------------------- 1995 Celica ST
Parts needed: 2x 14" steel rims Washer fluid resevoi |
chaynes CV axle removal Jun 27, 2008 - 10:58 PM
808celica i believe you can get the whole axle and replace t... Jun 28, 2008 - 12:47 AM
99Celica I believe theres some kind of lock, I don't kn... Jun 28, 2008 - 12:57 AM
chaynes 808 Celica: Car is a manual. I bought the CV axles... Jun 28, 2008 - 8:46 AM
Bitter my new-rebuilt axles didnt come with the dampener ... Jun 28, 2008 - 9:08 AM
soulshadow Get underneath with a long pry bar or a flat head ... Jun 28, 2008 - 3:54 PM
chaynes Yes! I will definitely replace the seals and g... Jun 28, 2008 - 3:57 PM
808celica look closely where you but the pry bar. you unbolt... Jun 29, 2008 - 5:55 AM
Bitter correct me if i'm wrong, but the 7afe has no c... Jun 29, 2008 - 7:20 AM
chaynes Correct, no carrier bearing on the ST. Thanks for ... Jun 29, 2008 - 8:53 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 13th, 2026 - 5:53 AM |
