> Best way to clean seats?
post Jul 7, 2008 - 3:06 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Everything else on the interior is fine, but due to the grain on the side supports, the seats have gotten a bit dirty/grody...any cleaning recommendations you guys use?
post Jul 7, 2008 - 3:57 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
dirty the rest of the interior so they look cleaner.
actually what if found to be the best was this orange can of carpet cleaner with an orange scrubber top to it.... i'm blanking on the name.... :X
post Jul 8, 2008 - 5:50 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Any other advice people?
post Jul 8, 2008 - 5:58 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Some car wash places have upholstery cleaners over where the vacuums are. I've always used these, with a pretty good degree of success. You could lightly Spray 'n Wash the seats, let it set for about ten minutes, then use the upholstery cleaner. It's a foam shampoo stuff that is basically a dry foam - you scrub it in with the brush thing and then vacuum it up. Works great.
post Jul 8, 2008 - 9:25 PM
i took the whole seat apart and washed it by hand. couple of members have done it to. there is a how to sticky on how to take the seats apart.
post Jul 8, 2008 - 9:37 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
I found Scotch-Gard uphostery cleaner worked very well for me after I bought my car (former owner was a smoker). Follow the directions carefully and you should be good, plus it doesn't take nearly as long to dry as a detailer's version.
Actually, I ended up using the Scotch-Gard after the detailer failed to do a good job -- my seats were certainly wet, but the car wasn't particularly well-cleaned.
post Jul 9, 2008 - 11:03 AM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
QUOTE (GriffGirl @ Jul 8, 2008 - 6:58 PM) *
Thanks, I'll probably try this!
QUOTE (njccmd2002 @ Jul 8, 2008 - 10:25 PM) *
Don't have the time/energy/need to do this, they're not that bad.
QUOTE (Galcobar @ Jul 8, 2008 - 10:37 PM) *
Thanks man!
Lo-Fi Version Time is now: August 24th, 2026 - 2:54 PM
