Jul 9, 2008 - 6:02 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 21, '08 From Naples, FL Currently Offline Reputation: 0 (0%) |
I'm sort of getting frustrated. I've had problems with my sunroof (http://www.6gc.net/forums/index.php?showtopic=59647) and now my passenger side window. Got in, started the engine (hasn't been driven for a week or so) and lower the windows as I usually do, only to find out my right one won't comply. There's no whirr from the motor, and it doesn't struggle either. It just doesn't do anything.
Please help. |
Jul 9, 2008 - 6:14 PM
Sounds like you have a wiring issue. If it's just the pass. window & not the d.s., check your connections where it comes into the cabin from the door (under the dash/glove box, down by where your right foot would be). It's a good place to start at least!
Jul 9, 2008 - 6:24 PM
Thanks. I already checked the fuse box for anything, and it looks intact...so I just checked under the glove box, but I have no idea what to look for. I checked everything that was visible and the wires are all safely attached as far as I can tell.
Jul 9, 2008 - 6:50 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '08 From Christchurch New Zealand Currently Offline Reputation: 0 (0%) |
Have you checked the button that stops the passengers window is not depressed?
-------------------- ![]() 1994年 トヨタ 神々しい My Facebook My Bebo QUOTE (loll6g @ Nov 6, 2008 - 5:53 AM) automatics are for lazy ass drivers who jst want there car so that they can look cool |
Jul 9, 2008 - 7:02 PM
Yeah. Neither one of the DS/PS buttons for the right window work.
Jul 9, 2008 - 7:03 PM
pull the switch panel out of the p/s window and make sure it's plugged in securely. Unplug and replug it. I bet it's just loose or something.
Jul 11, 2008 - 2:02 PM
Where is the switch panel located, and what does it look like?
Assuming it's under the glove box? |
Jul 11, 2008 - 5:32 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
by panel, its where the buttons are located, pull up at the bottom and the top has a clip pull down after you undo the bottom to pull it out
Jul 12, 2008 - 11:43 AM
What? That was totally unclear.
Jul 21, 2008 - 10:40 AM
Okay, so I have no idea how or why, but I'm just thankful. I was just randomly trying the window hoping it would just fix itself and work, but to no avail. Apparently somebody up there was listening. Had a lady friend in the car and shes opened the window before I could tell her it doesn't work, but it opened anyways. Same deal with the sunroof. It opens and closes fully now, except the motor seems like it might be working a tad bit too hard.
I'll still get it checked out, but I'm just glad that it finally works now. And even though I know it's not the cause, this happened right after I put a full tank after 900 miles of just filling it partially. Coincidence I guess. |
Jul 21, 2008 - 12:35 PM
Must've been the blinker fluid reservoir was clogged.
Jul 23, 2008 - 5:40 AM
Enthusiast ![]() Joined Apr 17, '07 From Greece Currently Offline Reputation: 0 (0%) |
Have the same problem...
Window Problem If i am correct, i hope not, your window will get stuck again. I am still looking for a solution by the way... -------------------- ![]() |
Jul 23, 2008 - 7:58 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 27, '02 From Derry,NH USA Currently Offline Reputation: 9 (100%) |
I HAD a similar problem...take off the plastics to the pass door. There is a wire there that apparently came lose for me and once I pushed it back in everything worked fine. Also,try looking at BOTH controllers on the door handle and push them in tightly.
Jul 23, 2008 - 3:15 PM
Must've been the blinker fluid reservoir was clogged. What? Have the same problem... If i am correct, i hope not, your window will get stuck again. I am still looking for a solution by the way... That sucks...I'm hoping it's just fixed, although usually things don't just fix themselves... I HAD a similar problem...take off the plastics to the pass door. There is a wire there that apparently came lose for me and once I pushed it back in everything worked fine. Also,try looking at BOTH controllers on the door handle and push them in tightly. I will try that. Thanks man. |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 1:15 PM |
