> st185 conversion
post Jul 10, 2008 - 2:15 PM
sous710
Joined Sep 13, '07
From upstate ny
has any 1 ever done a awd conversion into a st from a st185? if so wat kinda fab work is involved? is there welding,drilling.... and does the st have the clearence for a driveshaft? i found a parts car with the engine torn apart.
post Jul 10, 2008 - 3:08 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
search is your friend
Kawi Love
post Jul 10, 2008 - 5:43 PM
QUOTE (sous710 @ Jul 10, 2008 - 3:15 PM) *
no.
what kinda fab work? serious fab work. custom subframe and mounting brackets in the rear. motor mount swap in the engine bay (easy), LOTS of welding and LOTS of making your own structures. you have to cut out the spare tire well + custom fuel cell & gas lines
ST should have enough clearance for drive shaft.
post Jul 10, 2008 - 6:13 PM
sous710
Joined Sep 13, '07
From upstate ny
QUOTE (playr158 @ Jul 10, 2008 - 5:43 PM) *
no.
but will the axels work? i dont kno if the wheel base is the same or if the axels will fit (wider body?). i havent had the time to gogle this yet
This post has been edited by sous710: Jul 10, 2008 - 6:14 PM
Lo-Fi Version Time is now: January 11th, 2026 - 10:04 PM
