> Rear Caliper Bolt
post Jul 20, 2008 - 10:23 PM
TrdPnoy
Joined Sep 6, '04
From Canada
Hey everyone, I was wondering if anyone knew what the size of the rear caliper bolt is. I broke mine while changing my rear pads.
Thanks
post Jul 20, 2008 - 10:29 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
mine did to, and to be honest i didnt get a new one. i just left it out and have not had any problems, that was months ago.
post Jul 21, 2008 - 6:24 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
im dreading the day when i get my new pads b/c of those bolts
エキサイティングカーレーシングチーム!
post Jul 21, 2008 - 8:09 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I was missing one for a while, and then i started to hear a loud clunk under braking. I found the whole caliper was hanging back off the rotor. I took the other bolt out and went to the hardware store and found an identical replacement Grade10 bolt. I think it cost me 1-2 bucks?
Don't cheap out. Go to the hardware store and get it fixed.
**** Photobucket
post Jul 21, 2008 - 8:46 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
edit: the ones that bolt the caliper to the assembly is 9mm diamater with 14mm head, there is a single bolt on the caliper itself and thats 12mm head and 7mm diameter
This post has been edited by lubu: Jul 21, 2008 - 9:19 AM
98% completion
aaRon
post Jul 21, 2008 - 8:50 AM
QUOTE (mneal2_92788 @ Jul 20, 2008 - 11:29 PM) *
wow I can't even begin to understand the retardedness behind this decision.
If you don't know the size, just take one of the ones you have off and with you to Home Depot to find a replacement.
post Jul 22, 2008 - 6:08 AM
Vince-Noir
Joined Apr 26, '07
From Nottingham, UK & sometimes Boston, MA
QUOTE (playr158 @ Jul 21, 2008 - 2:50 PM) *
Little harsh perhaps! laugh.gif But true, generally speaking if you lose one you will know about it as you should hear some clanking/clinking coming from the wheel area - its there for a very good reason obviously so as said above - don't skimp, get it sorted properly! smile.gif
post Jul 22, 2008 - 6:47 AM
truth hurts?
post Jul 22, 2008 - 10:31 AM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
ANY parts store will have that caliper bolt too. Any hardware store, any parts store, any place that sells nuts and bolts will have it. I couldn't even imagine not replacing that. Wow.
post Jul 22, 2008 - 11:53 PM
TrdPnoy
Joined Sep 6, '04
From Canada
QUOTE (playr158 @ Jul 21, 2008 - 1:50 PM) *
DON'T BE SO HARSH LIKE THE PEOPLE ON HONDA FORUMS.
I don't think its retarded at all, I started changing my pads early in the morning before work and as I was finishing the rear right the bolt busted and the thread was stuck I had to drill it out the next day. I didn't bother taking the bolt out on the other side because I had to go to work. So I created this topic so that maybe I could go online during my break and see the replies then just grab it at work from the parts guys. I would of took the other one off if I had time. But Yah its not good to leave it.
Thanks for the replies.
This post has been edited by TrdPnoy: Jul 22, 2008 - 11:58 PM
post Jul 23, 2008 - 12:00 AM
TrdPnoy
Joined Sep 6, '04
From Canada
QUOTE (GriffGirl @ Jul 22, 2008 - 3:31 PM) *
Ya I didn't drive it to work without. I had another car to use.
post Jul 23, 2008 - 11:32 AM
GriffGirl
Joined Feb 7, '07
QUOTE (TrdPnoy @ Jul 22, 2008 - 9:53 PM) *
I think the comments are more out of genuine concern for another member's safety and not intended as insults.
/thread wink.gif
post Jul 23, 2008 - 12:03 PM
god you people need to grow up and stop expecting the world to be lollipops and sugar canes.
to start off with my comment wasn't even directed towards you OP, so don't get into a bunch.
Plus do not be ignorant and make blanket statements, it makes you look retarded. I bet a bunch of people on Honda forums > you.
Yes leaving a bolt out on a caliper is retarded. why?
if a mechanic did the brakes for you and left out a mounting bolt and you found your caliper flapping around after surviving brake failure while driving down the street....what would you do? Go back call him a retard and probably threaten to sue him.
secondly its retarded because you are putting other people potentially at risk by driving an unsafe car. Remember what you do to/with your car effects other peoples safety. Brakes are serious business don't leave sh!t out.
post Jul 23, 2008 - 3:20 PM
QUOTE (Tigawoods @ Jul 21, 2008 - 7:24 AM) *
Its super easy.
post Jul 23, 2008 - 3:28 PM
GriffGirl
Joined Feb 7, '07
It really is, actually. Fear not, grasshopper. Even a girl can do it. wink.gif
post Jul 23, 2008 - 3:48 PM
post Nov 6, 2011 - 3:46 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
my rear caliper bolt is broke and i am going to attempt to drill it out. what size drill bit should I use for this?
post Nov 6, 2011 - 4:05 PM
mkernz22
Joined May 10, '10
From MA
anything smaller than it really
post Nov 6, 2011 - 6:09 PM
95CelicaST
Joined Feb 5, '05
Typically you would drill a smaller hole in the center and use an extraction kit to back it out. It's pretty simple. Don't try to drill it out with a bit of the same diameter. You will not do it properly.
**** Photobucket
post Nov 7, 2011 - 10:10 AM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (95CelicaST @ Nov 6, 2011 - 7:09 PM) *
You can get a new caliper bolt and bracket at rock auto. com but the quality is kinda weak. I had a bolt that was stripped cause someone
forced it at an angle. Caliper brackets are around 16 bucks. Make sure to put in the notes please inspect just for the hell of it.
Lo-Fi Version Time is now: August 27th, 2026 - 1:05 AM
