Jul 24, 2008 - 4:02 PM
Enthusiast ![]() Joined Aug 22, '07 From Downriver, Michigan Currently Offline Reputation: 0 (0%) |
Okay, So I put a new radiator into my 94 GT. Everything is working fine... However - If I drive, say, 10 miles, everything is cool. No problems. If I drive, say, 20 miles or longer, I'm getting coolant coming out of the little hole near the top of my reservoir. it's gathering underneath my battery. Has anyone had this problem? All my hoses are clean and not blocked. And again, for short distances, she's totally cool. I don't get it. At a loss, LD -------------------- My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
94 Celica GT 89 Sentra Sport Coupe Project (the other haggard woman) ![]() |
Jul 24, 2008 - 7:57 PM
do a compression test
Jul 25, 2008 - 1:45 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
Is your resevoir almost empty when the car is cool?
Sounds to me like your resevoir is overfilled, and when the fluid heats up and expands on longer trips, it overflows the resevoir. |
Jul 26, 2008 - 9:36 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
Try a new radiator cap first.
-------------------- ![]() Project ST204.5 99.88946% complete... |
Jul 26, 2008 - 10:28 AM
you may have air trapped in the system
Jul 27, 2008 - 1:23 PM
Thanks for all the replies.
It's a brand new radiator cap and radiator. The cap looks fine. I'm leaning towards the air in the system. I do a pretty thorough job when I do my radiators...but I could have over-looked it when doing it. I'm going to check everything out today while I have the time. The Reservoir could be over filled too. I don't know why the hell I didn't think about that. I think I was presuming the worst and over looking the simple stuff. Again, thanks for the replies. I'll let you guys know the verdict. This post has been edited by Lexicon_Devil: Jul 27, 2008 - 1:24 PM -------------------- My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
Jul 27, 2008 - 2:22 PM
when the old rad went bad, did you overheat the car at all?
Jul 27, 2008 - 3:45 PM
It got hot for a second. I caught it and blasted the heat to get the temp down and
immediately stopped driving the car until I replaced it. -------------------- My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
Jul 27, 2008 - 3:59 PM
it indeed could be an air pocket. does your heat blow hot?
Jul 27, 2008 - 4:04 PM
I'm going to go start her up and check it all out. You have any tips on making sure she's "air less"? -------------------- My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
Jul 27, 2008 - 4:17 PM
Alright, She's got full heat. I let her warm up pretty good and gave her some RPMs... -------------------- My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
Jul 27, 2008 - 4:20 PM
thats encouraging. now hold a fast idle for about 5 minutes (1500-2500 rpm). that should get it upto full temp quickly. now listen for the fan to come on. it should come on when your coolant temp gets around 200-215F. though that doesnt help you unless you have a temp gauge or a pyrometer.
Jul 27, 2008 - 6:45 PM
Okay, I took her for another ride.
My coolant was topped off and my reservoir wasn't over filled. I drove up the road (50-55 mph) for about 10 miles. Pulled over, checked it out, and there wasn't any overflow. The temp gauge was at about 1/3 As I approached 15-17 miles, my temp gauge jumped up to just under halfway. I pulled over, jumped out and checked, and sure enough, there's this "puke spot" of coolant all around my battery. It wasn't continuing to ooze out. Just the puke spot. Weird, right? So I drove home and the temp gauge stayed right at under halfway. When I pulled into my driveway, I checked again and there doesn't seem to be any more that came out. Like the coolant puked once. I'm gonna check the level after she cools down. Also, It's 82 degrees here and the heat worked while driving. Weird, right? This post has been edited by Lexicon_Devil: Jul 27, 2008 - 6:48 PM -------------------- My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
Jul 27, 2008 - 7:18 PM
a little odd. are you sure the cooling fans are coming on?
once its hot, does it idle normal or rough? runs smooth or rough? any misfires once its hot? -------------------- |
Jul 27, 2008 - 7:27 PM
I'm checking the fans in a minute...but I'm pretty sure they're coming on.
Almost positive. Could they be shutting off or something? Runs perfect once it's hot. That's another reason I can't figure this one out. This is a caper. Call in the Hardy Boys. Thanks for the help, bro. btw... This post has been edited by Lexicon_Devil: Jul 27, 2008 - 7:28 PM -------------------- My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
Jul 27, 2008 - 7:44 PM
it could have just been air trapped in the system.
when bleeding the cooling system of air you need to fill rad through cap while squeezing hoses run car with cap off and heat turned on hold engine at 2500rpm till heat gets hot turn heat on low or off wait for thermostat to open and all air to bleed out fill rad back to full, make sure overflow is full put cap on wait for fans to come on wait for fans to come on again turn car off for several hours top off coolant jug as needed run car till fans come on take it around for a drive making sure it runs normal, heat works, temp stays steady when doing the rad its a good idea to do the thermostat and hoses as well. -------------------- |
Jul 27, 2008 - 8:06 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
did u bleed the air out of ur cooling system?
-------------------- BANNED. for life, you moron.
Jul 27, 2008 - 9:01 PM
Alright. After an entire night of checking everything, I checked the
fan thermostat and the plug from the wiring harness seems really damaged. It almost fell off. The plastic is really brittle and now it won't go back on tightly. So, I'd say that's 100% of my problem. Would you? Now I just have to find the plug for the damn wiring harness. -------------------- My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
Jul 27, 2008 - 9:25 PM
that'll do it! the fans probably are either not coming on or doing so intermittently. you can probably get on from a junkyard, if not then i know toyota sells those harness pigtails. just assemble it yourself, you'll see when you get it.
Jul 27, 2008 - 9:28 PM
Yep. It's junk-yarding for me tomorrow.
Thanks for all the help. I was seriously stumped on this. When I changed the radiator, the fan thermostat plug seemed to snap on just fine. It probably broke when putting it on. I feel like kicking myself in the ass for not noticing it sooner. Hah! -------------------- My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
| Lo-Fi Version | Time is now: August 21st, 2026 - 10:36 PM |
