Aug 1, 2008 - 2:39 AM
Enthusiast Joined Aug 1, '08 From Santa maria Currently Offline Reputation: 0 (0%) |
I have a valve cover leak in one of the O rings leaking were the spark plugs go in. I have a 1994 Gt. Looks like it will be simple to fix just unscrew new o ring rescrew. Is there Anything else i should be aware of when i change the O ring?
Aug 2, 2008 - 11:00 AM
obviously the whole valve cover gasket, the other tube seals, and another pretty common leak on the head is the distributor shaft seal. that one is a little more involved because you can mess up your ignition timing if you dont go back together right. the valve cover job however is pretty straight forward.
Aug 2, 2008 - 1:12 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
I just did mine like onth ago and I remember something about how all the tabs on the o-rings had to face the alternator.
Aug 7, 2008 - 8:22 PM
i want to put my new valvecover so just buy the gasket and the rings?
| Lo-Fi Version | Time is now: August 29th, 2026 - 7:37 PM |
