> I want to swap OEM head units (Need some help)
post Aug 1, 2008 - 6:43 PM
Tech-Nics
Joined Jun 18, '08
So me and my wife have the same Celica, same color, both are hatchbacks. The only difference is she has the 96 ST LTD & I have the 94 GT. Now I have the Premium sound system with the eight speakers & the OEM AMP. I want to know if I can do a direct swap with my wife's OEM radio even though she has the OEM 4 speaker system with no AMP. Are the plugs the same on the back of the decks? Does it matter that I have an AMP and she doesn't. I mean they are both Toyota OEM head units.
Thanks.
This post has been edited by Tech-Nics: Aug 1, 2008 - 6:44 PM
post Aug 1, 2008 - 11:45 PM
azian_advanced
Joined Apr 18, '05
From Calgary
the plugs leading to the stereo are different between a 'standard' 4-speaker toyota stereo vs a 8-speaker toyota stereo.
you will have to bypass your stock amp for this stereo to work. but i'm not sure if the sound will come out from all 8 speakers.
the plugs that lead to the speakers is the same as the plugs that connect to a 4 speaker toyota stereo.
8-speaker stereo setup
post Aug 2, 2008 - 11:32 AM
trdproven
Joined Aug 2, '05
From Guam
On an 8 speaker system, you have to bypass the amp. 1 under the player and one under the chair but by bypassing, all speakers will turn on except for the door subs that WAS powered by the amp under the chair which will no longer work. You can remove the stock one and put an aftermarket version.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 1st, 2026 - 10:02 AM
