Aug 4, 2008 - 10:39 PM
Enthusiast ![]() ![]() Joined Jun 16, '07 From Vancouver, Canada Currently Offline Reputation: 14 (100%) |
Hey Guys, I'm not sure if this should be in the off-topic or in engine maintenance. I started this topic in engine cause it partly related to the 6 gen celica. I've been working on a 88 celica with a 3sge engine trying to gain some experience in swapping before i do my 95 celica.
The plan was to swap out the usdm block and internals for a jdm block and its internals because the usdm crankshaft was badly damaged. During this swap I've encountered a few differences, for example the pistons are different (jdm have wedge top as where usdm have a flat top). The one difference that I'm stuck on is the flywheel. The usdm flywheel (11-1/4") is smaller than jdm flywheel (12") and the hole for mounting are slightly off. The jdm flywheel is actually a 5sfe flywheel. I know that both celica uses The S53 tranny, so is there anyway to make a hybrid flywheel? or some sort of setup that would work. * usdm starter is in a difference place compared to the 5sfe starter I need the size of a usdm flywheel with the mounting holes of a 5sfe flywheel. If you guys have any tips or suggestions that would be awesome, THANKS! -------------------- ![]() |
vile_v 3sge jdm swap Aug 4, 2008 - 10:39 PM
Smaay use the flywheel for the specific crank. you dont ... Aug 5, 2008 - 10:47 AM
Dr_Tweak I can make you any type of hybrid clutch you need,... Aug 5, 2008 - 3:08 PM
vile_v QUOTE (Smaay @ Aug 5, 2008 - 4:47 PM... Aug 5, 2008 - 7:22 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 8:26 AM |
