> Cold air intake performance
post Aug 7, 2008 - 1:14 AM
recniabsal
Joined Nov 4, '07
From utah
Ok I have a major slice in the tube for my stock air intake and so I am thinking of replacing the whole thing. I have a K&N filter and I drilled a big hole in the bottom of the air box. But I went to ebay.com and saw a cold air intake included with a K&N filter that would fit the intake. I have heard rumors that they perform ****ty during rain or winter. Its 105.00. Do you guys think its worth it performance wise? Cost isn't too much to me as long as it would last a long time and perform well.
sig removed for size and content.
Replies (1 - 9)
post Aug 7, 2008 - 1:42 AM
xredjokerx
Joined Apr 18, '08
From Oakland, bay area, California
dont get the ebay one because that one gets air from near your radiator but in fact it should be in the fender area where true cold air is. so its easier to build your own apparently, which i cant do because i dont have ANY of the tools >__> so... im in the same position you are >__<
post Aug 7, 2008 - 12:49 PM
reko
Joined Apr 17, '07
From Montreal, QC, Canada
QUOTE (xredjokerx @ Aug 7, 2008 - 2:42 AM) *
Just remove the plastics that ''protect'' your engine from water / mud / dust under your engine
post Sep 16, 2008 - 10:55 AM
ratzer
Joined Dec 25, '07
From Pittsburgh, PA
buy a cold air intake for a 90-93 honda accord. all you need to do is make like one or two cuts.
post Sep 16, 2008 - 11:02 AM
reko
Joined Apr 17, '07
There is traps in the plastic just where the filter sits
post Sep 16, 2008 - 11:12 AM
slow_yota
Joined Mar 3, '07
From Sunny Florida
I had a cai that i welded together..was very nicely done but i felt like the car was way more boggy..I hated it, I put my factory air box back on and installed a drop in K & N...Just my .02$
post Sep 23, 2008 - 10:18 PM
mspired13
Joined Jun 11, '08
From Seattle
CAI dyno runs hav eproven time and time again to have better gains in power, due to the fact that colder air leads to better fuel combustion (drive on a cold day, and drive a hot day). CAI have a longer lag in throttle response, as it takes more time for it to fravel from the filter to the engine. Not too much, but noticable. If you were to go this route, seeing tha tyou live in Utah, you might want to consider an AEM air by pass valve. This little device will prevent your engine from sucking up water. Soem people have short ram or pop chargers. They have reduce air travel time and like wise have better throttle response. If you run one of these, you will need to run a heat shield as it will suck the hot air in the engine compartment. I like your idea of drilling holes into the airbox. A trick that old school racers used before CAI and the sorts. I did this on my 92 integra, poped a high filtration panel filter, Drilled three big 1.5 holes onto the sides, and bottom of it, ran a good size tube to catch some ram air effect and closed the hood. Sounded evil, but when people poped the hood, everything looked stock. Which is kind of nice wink.gif Plus it keeps the heat away from the air.
This post has been edited by mspired13: Sep 23, 2008 - 10:20 PM
post Sep 24, 2008 - 7:12 PM
Akirad1
Joined Jun 2, '08
From Fort Worth, Texas
if you want the one from ebay i have one for sale with the filter just not k&n.
post Sep 24, 2008 - 8:27 PM
97celiman
Joined May 22, '08
From dallas texas
unless your going through water that you shouldnt be going through in the first place (high than half you wheel) you wont have to worry about hydro-lock...talk to darthripley...they got it down
post Sep 26, 2008 - 6:21 PM
reko
Joined Apr 17, '07
Overall view
Cold air intake main view
How its fixed
Sensor
Top view
Air trap on filter side
Air trap on manifold side
This post has been edited by reko: Sep 26, 2008 - 6:21 PM
Lo-Fi Version Time is now: August 31st, 2026 - 6:47 PM
