> Engine Wont Start: PROWLING TEH STREETS ONCE AGAIN!, oh yay's
post Aug 10, 2008 - 8:16 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
to make a long story short
i was on my way to the 2nd day of auto-x 2day and my car shut off on my 2 miles away from the track.
after fumbling around with it and getting help over the phone from art here is the info i have gathered
- plugs are dry
- battery is fine
- YES i had gas!
- no spark
- rotor isnt turning
i plan on checking the fuel filter tomorrow before i get into the timing belt
art said it was most definitely the timing belt but i have yet to check it.
just wanted to get some last minute opinions
3 1/2 hours later timing belt on and the car is running again!!!!!
it wasnt too hard my buddy and i took it apart and put it back together in record time!!!
This post has been edited by Tigawoods: Aug 13, 2008 - 5:12 PM
エキサイティングカーレーシングチーム!
post Aug 10, 2008 - 8:23 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Well if your rotor isn't turning then, more than likely your timing belt broke on you.
94 Celica gt white (sold)
post Aug 11, 2008 - 7:46 AM
stevest202
Joined Oct 28, '07
From epworth uk
timing belt if rotor not turning is it a non interference engine same as the 3sge engine
post Aug 11, 2008 - 3:05 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
im not sure if the 5sfe is or is not a not interference
エキサイティングカーレーシングチーム!
post Aug 11, 2008 - 3:40 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
it isnt. opened up the casing and indeed the belt had snapped
エキサイティングカーレーシングチーム!
post Aug 11, 2008 - 4:23 PM
stevest202
Joined Oct 28, '07
From epworth uk
QUOTE (Tigawoods @ Aug 11, 2008 - 4:40 PM) *
hopefully if its a non interference engine there wont be any damage and you can just pop new timing belt on with no damage done heres hoping for you man smile.gif
post Aug 11, 2008 - 5:40 PM
Remy
Joined Jan 25, '06
From MN
I think the 5sfe are non interference I believe.
"To Protect And To Serve The Wealthy" -POLICE
post Aug 11, 2008 - 6:12 PM
brk34
Joined Jan 20, '08
second this non inter firence engine
This post has been edited by brk34: Aug 11, 2008 - 6:13 PM
post Aug 11, 2008 - 6:33 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Yes its non interference. Just put a new timing belt on. Whille you're in there change out the crank seal and water pump.
post Aug 11, 2008 - 6:43 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (bccentaur3 @ Aug 11, 2008 - 7:33 PM) *
water pump has been changed not too long ago. since im not sure what caused the break i am going to replace the tensioner as well
エキサイティングカーレーシングチーム!
post Aug 13, 2008 - 5:12 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
エキサイティングカーレーシングチーム!
Lo-Fi Version Time is now: September 4th, 2026 - 10:57 AM
