Sep 18, 2003 - 9:26 AM
Enthusiast ![]() ![]() Joined Sep 18, '03 From Dirty Jersey Currently Offline Reputation: 0 (0%) |
hey did anyone see the 6th gen celica in super street about a month ago? it said it had a veilside 6 speed transmition. does anyone know where i can get ahold of one?
Sep 18, 2003 - 10:28 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Awhile back that was talked about on here...and it was pretty much concluded that they meant the veilside shift knob had a 6speed shift pattern on it.
EDIT- But speaking of which. i really want a 6spd tranny...in 5th gear i hit like 3.5-4k on the tach when i go about 70-75 on the highway. Im sure it eats up gas pretty bad, and when i go even faster i feel like i would run out of gear at about 100. This post has been edited by Silver94CelicaOwner: Sep 18, 2003 - 10:33 AM -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Sep 18, 2003 - 11:21 AM
![]() Enthusiast ![]() Joined Oct 1, '02 From Belgium Currently Offline Reputation: 0 (0%) |
If you got the ST, you can pull out your gearbox and replace it with the 6 speed gearbox from the 7th gen celica
One of the only times i'm glad i bought an ST... |
Sep 18, 2003 - 12:42 PM
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
I heard HKS makes a 6spd tranny. I have yet to find it.
Sep 18, 2003 - 5:56 PM
does anybody know where i could get one and how much a 7th gen gearbox would cost
Sep 18, 2003 - 6:10 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 30, '03 From Virginia Currently Offline Reputation: 0 (0%) |
I don't know, but I'd just go to a Toyota dealership where no one knows you and ask about getting a replacement gearbox for your 6 speed 7th gen. Haha.
Sep 18, 2003 - 6:33 PM
who said that a 2zzge tranny would bolt up to a 7afe?
i know that all 4age tranny's bolt up and that one model 4ag(z)e engine came with a 6speed tranny -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Sep 18, 2003 - 6:37 PM
I was just telling him how he could get one. I never said if it would work or not.
Sep 18, 2003 - 11:12 PM
Enthusiast ![]() Joined Mar 21, '03 From Pittsburgh, PA Currently Offline Reputation: 0 (0%) |
Has anyone put the 7th gen tranny in a 6th gen ST yet? I do a ton of highway driving and would love to have an extra gear. If the gear ratios were changed and made wider wouldnt it make my car slower than it already is though? As we all know the ST cant afford to lose much power.
Sep 19, 2003 - 12:40 AM
![]() Enthusiast ![]() ![]() Joined Apr 8, '03 From NorCal Currently Offline Reputation: 0 (0%) |
That 6 speed tranny is RWD... I highly doubt the 2ZZ tranny will bolt up to the 6th gen... |
Sep 19, 2003 - 1:07 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
lol....
there is no way it would work. However, the 4age black top 6spd will work on an ST. Good luck doing it though. Jon |
Sep 19, 2003 - 2:01 AM
Actually...I don't think the 4A blacktop tranny will work either... It's a RWD tranny... |
Sep 19, 2003 - 11:15 AM
Are you sure? I had no idea they were rwd...
Jon |
Sep 19, 2003 - 3:07 PM
Enthusiast ![]() ![]() Joined Sep 5, '02 From Winter Haven, FL Currently Offline Reputation: 11 (100%) |
The Black Top 20v transmission is FWD...I don't think they would go from a FWD Silver Top and drastically change the drivetrain to RWD with the Black Top.
You are probably thinking of the older Corollas (AE86) with the 4AGE and RWD. |
Sep 19, 2003 - 8:46 PM
Enthusiast ![]() ![]() Joined Sep 16, '02 From Somewhere around Chi-Town Currently Offline Reputation: 0 (0%) |
um... even tho it is RWD, it should still work with some modification. i mean look at all the guys running around with 3sgte's that have Mr2 tranny's. mr2 = RWD. to my knowledge that should work, but u need some modification to it. i believe u take one part off of the tranny and put that same part except from your original tranny on it and it works. of course its not as simple as what i just said, but from the GT comparison, it should work on an ST.
EDIT: or maybe it isnt RWD, either way it should work w/ slight mods. This post has been edited by Pvc99gT: Sep 19, 2003 - 8:47 PM |
Sep 19, 2003 - 9:57 PM
Apparently nobody read/believes what I posted earlier. The 6 spd Transmission found on the AE111 Black Top 4AGE 20v is freakin' FRONT WHEEL DRIVE! And that transmission only came with the Blacktop 20v (read not 4AGZE). Hell if anyone doubts me check out Jarco and give them a call since they have 3 Black Top clips with 6 spd trannys.
BTW: if anyone is interested in a AE101 4AGZE front clip, Jarco has one with 63k miles for $1995 And about the MR2. If you consider where the engine is located and how it is set up you will realize it is much like a FWD Transverse mounted engine, but only in the rear. The only person that I know of that has used the MR2 tranny with a 3SGTE is Dirty. |
Sep 19, 2003 - 11:06 PM
and that's what I thought as well. Jon |
Sep 19, 2003 - 11:35 PM
I never heard that HKS made trannys??? |
Sep 19, 2003 - 11:51 PM
Sep 20, 2003 - 1:17 AM
I stand corrected... I always thought the Levins were RWD... cause they were offshoots of the Truenos, which were sporty RWD corollas... similar to the Levins... As for the MR2...it's a Mid engine design... so it's not really considered a RWD tranny... and no...you cannot modify RWD trannys to work with FWD cars. RWD trannys don't have sprockets for axles (as far as I know)... instead, they transfer power through a drive shaft to a rear diff to the rear wheels... This post has been edited by Kwanza: Sep 20, 2003 - 1:18 AM |
| Lo-Fi Version | Time is now: February 16th, 2026 - 12:23 AM |
