> Overheating...., Diagnose my problem?
post Aug 15, 2008 - 12:59 AM
95GTCelica
Joined Oct 25, '07
From los angeles
Alright 6GC People I need your help...
Today after driving for about fifteen/twenty minutes I parked and noticed that the temp gauge read above the red line and the H. Popped the hood and heard gurgeling coming from the radiator with some overflow. I let it cool down for an hour then came back and drove around the block a couple times. I noticed that the temperature goes through the roof when it starts and slowly climbs. But when i hit about 40mph it cools down to about 3/4 of the way and when i stop it goes straight back up. I had a similar problem like this before and it was a bad water pump which was replaced a few weeks ago. Today there was no coolant on the ground just the few drops that spilled from the overflow. The engine seemed to be running fine and I wouldnt have noticed anything wrong with it unless i looked at the temp gauge. So can anyone help me? Any ideas? I'm stumped.
- 95GTCelica   Overheating....   Aug 15, 2008 - 12:59 AM
- - lubu   I think ur fan (or sensor which ultimately respons...   Aug 15, 2008 - 1:20 AM
- - 95GTCelica   I dunno....When I get out of the car both are on, ...   Aug 15, 2008 - 5:57 AM
- - Batman722   change your thermostat, it's bad.   Aug 15, 2008 - 11:11 AM
- - DEATH   And stop driving it like that until you do change ...   Aug 15, 2008 - 11:17 AM
- - GriffGirl   It totally sounds like your thermostat is sticking...   Aug 15, 2008 - 11:29 AM
- - lubu   Another theory is that you might have a clog withi...   Aug 15, 2008 - 11:40 AM
- - 95GTCelica   Is there any way for me to test if the thermostat ...   Aug 15, 2008 - 2:02 PM
- - GriffGirl   Truthfully for the process to test the thermostat,...   Aug 15, 2008 - 3:13 PM
- - 95GTCelica   yes please! that would help out alot. thanks   Aug 15, 2008 - 3:53 PM
- - DEATH   Yeah I agree with Griffy - thermostats are cheap a...   Aug 15, 2008 - 3:55 PM
- - 95GTCelica   yeah that sounds awesome...i guess i will see if i...   Aug 15, 2008 - 4:06 PM
- - Remy   OEM thermostat for 95 celica its under oem parts--...   Aug 15, 2008 - 5:29 PM
- - Bitter   are the cooling fans coming on at all?   Aug 15, 2008 - 6:38 PM
|- - lubu   QUOTE (Bitter @ Aug 16, 2008 - 7:38 ...   Aug 15, 2008 - 6:51 PM
- - Bitter   does your coolant smell...well it should smell lik...   Aug 15, 2008 - 7:03 PM
- - cheeco   radiator fins are probably clogged with debris. re...   Aug 15, 2008 - 10:43 PM
- - 95GTCelica   QUOTE (Bitter @ Aug 15, 2008 - 8:03 ...   Aug 15, 2008 - 11:24 PM
- - Renegade   head gasket can be an issue too? if u went past t...   Aug 16, 2008 - 12:04 AM
- - DEATH   Seriously don't forget to change the cap too. ...   Aug 16, 2008 - 10:34 AM
- - 95GTCelica   QUOTE (Renegade @ Aug 16, 2008 - 1:0...   Aug 16, 2008 - 10:35 AM
- - 95GTCelica   Well it didn't work...back to square one. But ...   Aug 16, 2008 - 1:22 PM
|- - Batman722   QUOTE (95GTCelica @ Aug 16, 2008 - 2...   Aug 16, 2008 - 11:24 PM
|- - Bitter   QUOTE (Batman722 @ Aug 16, 2008 - 11...   Aug 17, 2008 - 9:03 AM
- - Renegade   it's ur head gasket, u will start to loose coo...   Aug 16, 2008 - 2:25 PM
- - 95GTCelica   alright i'll try that im due for another oil c...   Aug 16, 2008 - 3:28 PM
- - 95GTCelica   no coolant in my oil.... any other suggestions?   Aug 16, 2008 - 9:49 PM
- - Bitter   oil and coolant mix doesnt always occur. do a co...   Aug 16, 2008 - 10:49 PM
- - 95GTCelica   It came straight from the dealer, picked it up mys...   Aug 17, 2008 - 12:17 AM
- - 95GTCelica   O.k so I did a compression test...twice, just to m...   Aug 17, 2008 - 10:10 PM
- - Bitter   eroded water pump, air pocket. just to be sure it...   Aug 17, 2008 - 10:57 PM
- - Batman722   I still think it's your thermostat.   Aug 17, 2008 - 11:49 PM
- - 95GTCelica   QUOTE (Bitter @ Aug 17, 2008 - 8:57 ...   Aug 18, 2008 - 3:36 AM
- - DEATH   If you didn't change the cap you'll be kic...   Aug 18, 2008 - 9:30 AM
- - nics   recently i had the same problem. it seems that the...   Aug 18, 2008 - 1:55 PM
- - cheeco   did you pull out the radiator and clean it? clogge...   Aug 18, 2008 - 10:14 PM
- - 95GTCelica   QUOTE (Batman722 @ Aug 17, 2008 - 9...   Aug 19, 2008 - 1:17 AM
- - nics   QUOTE (95GTCelica @ Aug 18, 2008 - 11...   Aug 19, 2008 - 8:49 AM
Lo-Fi Version Time is now: June 25th, 2026 - 9:08 PM
