> Bad ECU??
post Aug 15, 2008 - 10:42 PM
babysupragt
Joined Jun 24, '06
From Houston.TX
Are 96-98 ecus the same for a 97 celica gt?? Switched ecus for a 96 ecu that I bought from the junk yard. The car turned on with the 96 ecu but later starting boggin on idle... then it died. Could it be the ecu or a bad sensor?? It threw check engine light for the ignitor on both ecus..
post Aug 15, 2008 - 10:50 PM
what was the code ?
post Aug 25, 2008 - 8:48 PM
babysupragt
Joined Jun 24, '06
From Houston.TX
P0105
post Aug 25, 2008 - 10:01 PM
MAP sensor.
make sure it's plugged in properly, make sure the vac tube to it is secure and going to the intake manifold. If those are ok then swap the MAP with another. I have a spare if you want it.
post Aug 26, 2008 - 1:11 AM
babysupragt
Joined Jun 24, '06
From Houston.TX
Is plugged in right and i have tried like 4 map sensors but my car just turns on for a bit and then turns off
Lo-Fi Version Time is now: September 9th, 2026 - 2:00 AM
