Aug 19, 2008 - 8:28 PM
Enthusiast ![]() Joined Aug 17, '08 From NY Currently Offline Reputation: 2 (100%) |
I just picked up a 96 celica for cheap, and the gauge cluster doesnt light up. Only the tach lights up and the warning lights underneath it light up, but the speedo, temp and fuel gauge and the warning lights on the right side of the cluster dont light up. The car has almost 200k miles, so could this be caused by the bulbs being burnt out, or is there something wrong with the cluster or wiring?
Aug 19, 2008 - 9:57 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 3, '07 From Sunny Florida Currently Offline Reputation: 18 (91%) |
try the 7.5 panel fuse under the drivers side dash...or just burnt bulbs..The panel fuse is a much easier fix though.
Aug 19, 2008 - 10:30 PM
do you know which fuse in the panel underneath the dash is for the gauge cluster?
Aug 19, 2008 - 10:48 PM
it's the fuse labeled "gauge"
Aug 19, 2008 - 10:59 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Aug 19, 2008 - 11:04 PM
Aug 19, 2008 - 11:40 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
yes
Aug 19, 2008 - 11:44 PM
Ok great, thanks.
Aug 20, 2008 - 7:23 PM
so i checked the fuse and it was fine, then i replaced the bulbs and the speedo, temp and gas gauge light up now. But with the key in the on position when the cars off, the only warning light that lights up on the right side is the check engine light. On the left side the airbag, battery, oil, door, and brake light are on if the car is off and the key is in the on position. Are there supposed to be more warning lights on?
Aug 27, 2008 - 12:38 PM
![]() Enthusiast ![]() ![]() Joined Apr 17, '07 From Montreal, QC, Canada Currently Offline Reputation: 1 (100%) |
so i checked the fuse and it was fine, then i replaced the bulbs and the speedo, temp and gas gauge light up now. But with the key in the on position when the cars off, the only warning light that lights up on the right side is the check engine light. On the left side the airbag, battery, oil, door, and brake light are on if the car is off and the key is in the on position. Are there supposed to be more warning lights on? No -------------------- |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 3:00 PM |
