> Welding stell pipes., how to..........
post Sep 19, 2003 - 7:29 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
Sup ppl. Does anyone here have any experiance welding steel?
i'm the kinda of guy that likes to learn new things every day, and today, i want to learn welding.
Is there something that i NEED to know about it? Are there certain tricks to it? Am i supposed to do it a certain way?
Replies (1 - 2)
post Sep 19, 2003 - 11:44 PM
Guest_Matthew_*
UMMM
I KNOW HOW TO WELD PRETTY GOOD. ALUMINUM IS REALLY HARD TO WELD AND IT TAKES A LONG TIME TOO. IF YOU MESS UP YOU HAVE TO START ALL OVER AGAIN
BUT PEOPLE POSTING ON A MESSAGE BOARD WONT BE ABLE TO TELL YOU HOW TO WELD.
GO TO A TRADE SCHOOL.
post Sep 20, 2003 - 2:08 AM
boosted_K2
Joined Aug 30, '02
From Michigan
yea go to a trade or technical school. you wont be able to just pick up a welder toss on a mask and weld perfect beads the 1st day, it takes months of getting it tuned in properly and learning where the heat and wire speed settings need to be. how long to hold a bead down and what kind of weld is needed for what application. I was thinking of becoming I-Car certified as a welder, but i figure its pointless untill i get into a position where id be welding at a company... which i dont see happening soon... but theres always a possability. and dont use the wire that supposedly works without gas, its crap, get a good lincoln welder with innert gas, they work well. also if you try doing MIG on aluminum you wont get anywhere, ever. you have to go TIG, which isnt too much more difficult, just takes more practice. also a good way to learn about welding and cutting metal is to play around with an ascetyline torch for a while.
No but I don't buy it
Cause I'm...
Lo-Fi Version Time is now: September 3rd, 2026 - 7:46 PM
