Aug 25, 2008 - 5:34 PM
Enthusiast Joined Apr 16, '08 From CT Currently Offline Reputation: 0 (0%) |
i have a 97 gt with an alarm that i believe came with the car. the alarm does not work and just kills my battery
leaving me to disconnect my battery everytime i park the car. i need to know if there is a way to remove it. and if there is maybe a fuse that i can take out for it that would help. please help |
Aug 25, 2008 - 7:14 PM
It would be helpful to know what kind of alarm it is... the box should be located under your driver's seat.
Aug 26, 2008 - 1:19 PM
i dont know what kind it is but im pretty sure it came with the car when it was bought at the dealer new.. i will check under the seat to see
This post has been edited by Dtuner17: Aug 26, 2008 - 1:20 PM |
Aug 26, 2008 - 3:38 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
It would be helpful to know what kind of alarm it is... the box should be located under your driver's seat. Or next to the steering column. If it's OEM you can take it to the dealer and they'll usually deactivate it for free or call them and they'll walk you through the procedure. I've had to do this for a couple of other members who had the same problem as you before. -------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Aug 26, 2008 - 11:04 PM
Enthusiast ![]() ![]() Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
I would think it would depend on who installed it. Different installers put them in different places, unless of course its OEM...
Aug 27, 2008 - 11:04 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
Dude, i just went thru a similar nightmare. And a nightmare it was
Start by getting under your stearing colom, Remove the 2 philips screws holding the panel with your dimmer switch and key hole and remove that panel. Then remove the panel above your knees in driving position. 4 philips and 2 "clips". Undo the hood release; 2 philips. Then you have to remove the bracket behind that pannel. 4 10MM bolts. Now you should be able to find a motion sensor, (box with a red and green light *usualy*) This is the most common place to mount thees things. Now follow the wiring band up to the "brain" of the unit. No telling where that's stuffed. You'll just have to follow the wiring. When you get to that 'brain' then you simply need to discounect EVERYTHING that it's attached to. MAKE SURE THAT IF SOMEONE HAS SPLICED THE WIRING THEN YOU PUT IT ALL BACK PROPERLY!! otherwise your car may not start, windows may not operate, doorlocks may not work, ect. G/L -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Aug 27, 2008 - 6:00 PM
thanks alot guys for your help i took my car to a friend today and he took it out for me
| Lo-Fi Version | Time is now: August 9th, 2026 - 9:55 AM |
