Sep 20, 2003 - 12:59 AM
Enthusiast ![]() ![]() Joined Jun 21, '03 From FRANKFORT,KENTUCKY Currently Offline Reputation: 0 (0%) |
I have a 93 st celica which has the 1.6 engine and an automatic transmission. Now here's my problem. I can be driving along and everything will be fine but all of the sudden it feels as if overdrive went out. At the exact moment it feels like overdrive went out the temp gauge will shoot down to cold. When it happens it only last for about 40 or 50 seconds. I am completely confused. My only thought is that maybe the temp sensor has gone bad and it is throwing the ecu off. Even that really doesn't make any sense. Please help me out. I thought I would check with you guys first to see if you all have any ideas.
Sep 20, 2003 - 1:33 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
does the car just'die for a second or two?
Jon |
Sep 20, 2003 - 1:59 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
Your car is posessed get a priest thats all I can do for u now.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Sep 20, 2003 - 2:02 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
electronics in general doesnt make sense. im sure its a messed up sensor or crossed wire somewhere....
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Sep 20, 2003 - 10:47 AM
![]() Enthusiast ![]() ![]() Joined May 17, '03 From Ontario, Canada Currently Offline Reputation: 1 (100%) |
OK, I know what is causing the problem. You are correct about the temp sensor. In a auto slushbox, there is a torque converter lock-up. Your tranny does not have OD as such, but what you are referring to is the torque converter locking up. It does feel like another gear. When the car gets up to a certain speed and the engine load drops below a threshold the converter will lock up, but only if the temperature has risen above a minimum threshold. The computer controls the lockup and with your wonky temperature readings, the computer is disengaging the lockup and your revs will increase. Fix the temp sensor problem and that will fix your tranny.
Sep 22, 2003 - 2:03 AM
thanks geekboy for the help,that's some great information.
| Lo-Fi Version | Time is now: September 2nd, 2026 - 6:39 AM |
