> Alpine deck
post Aug 27, 2008 - 10:43 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
I just picked up an alpine deck CDA-7894. There are no place for RCA cables on the deck, anyone know how this works? I need the RCA plugs for my amp.
thanks for any help.
Replies (1 - 19)
post Aug 27, 2008 - 11:29 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
uh well then u cant run an amp off of it....
BANNED. for life, you moron.
post Aug 27, 2008 - 11:42 PM
mikecelica
Joined Jan 31, '07
I gotta find a way, its supposed to be one of the best head units alpine ever made, the guy i bought it from said something about having 4volt preamp outputs instead of most decks with only 2volt, which make it sound soo much better.
This post has been edited by mikecelica: Aug 27, 2008 - 11:43 PM
post Aug 27, 2008 - 11:53 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
specs??
post Aug 28, 2008 - 12:06 AM
mikecelica
Joined Jan 31, '07
Turbocharge your MP3s with V-Drive™ high power! Alpine put their most potent MOSFET60 hybrid amp into the CDA-7894 CD receiver, so your music will have the punch and clarity it deserves.
The CDA-7894 plays MP3 files burned onto CD-Rs and CD-RWs as well as standard discs, so you can bring your Internet favorites along. It'll decode and display MP3 text info (ID-3 tags) plus CD Text on its bright readout. Plus, the faceplate buttons can be illuminated green or amber, so you can match your vehicle's dash lighting.
Read More
If all that V-Drive power just isn't enough, use the super-clean 4-volt front, rear, and subwoofer preamp outputs to add Alpine Bass Engine component amps and subs. And when you order a receiver/CD changer combo, you'll save $$ with our package discount. A wireless remote is included.
Important Note: The powerful output of Alpine's V-Drive internal amplifier requires a direct fused connection to your vehicle's battery! We recommend that you purchase a 10-gauge amp wiring kit with this receiver (see "Featured Accessories," at right).
Details:
motorized, detachable face
switchable green/amber button illumination
blackout display mode — turns off display, reduces power consumption, and enhances sound quality
MaxTune SQ tuner
18 presets
V-Drive hybrid MOSFET60 internal amp — high-current draw requires direct fused connection to your battery (see "Wiring Note" in the Detailed Info section)
plays MP3 files on CD-R or CD-RW plus audio CDs, CD-Rs, and CD-RWs
Bass Engine® Plus (bass center frequency, width, and level, plus treble center frequency and level adjustments, as well as 4-channel digital time alignment and a 3-position, 12 dB/octave crossover)
Media Xpander™
XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal.) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
CD changer controls for Alpine Ai-NET changers only — add an Alpine changer to your receiver order, and save $$ with Crutchfield's package discount
optional auxiliary input
4-volt front/rear/subwoofer preamp outputs
wireless remote
clock
27 watts RMS/60 peak x 4 channels
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
post Aug 28, 2008 - 12:37 AM
CelicaST_CALI
Joined Feb 28, '07
From Banland
they have to be there someowhere,pics??
post Aug 28, 2008 - 3:46 AM
Rizer
Joined Aug 20, '08
From Norway
Try this link
User manual
post Aug 28, 2008 - 7:06 AM
spolski07
Joined Jul 7, '06
From Los Alamos, NM
did you buy it used? the text says you should have 3 sets of rca preouts.
if you cant figure it out, pick up a couple of adjustable line out converters from your local best buy
these "create" rca's by tapping into the speakers, they are mostly used by people who want a sub on their factory head unit.
btw
what amps are you running?
This post has been edited by spolski07: Aug 28, 2008 - 7:12 AM
post Aug 28, 2008 - 7:38 AM
mikecelica
Joined Jan 31, '07
This is my full setup:
Two 200W 6.5" Phoenix gold speakers in front
Two 200W 5.25" Phoenix gold speakers in rear
One 600W 12" Phoenix gold sub
One 800W Sony Xplode amp
One 1.5 Farad Capacitor
Alpine CDA-7894 head unit
*PLus I have an extra 4-channel amp that Im deciding wether or not to amp the speakers.
This post has been edited by mikecelica: Aug 28, 2008 - 7:38 AM
post Aug 28, 2008 - 7:41 AM
welcome to the alpine club.
post Aug 28, 2008 - 11:10 AM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
I can't wait to throw my Alpines in.
post Aug 28, 2008 - 4:33 PM
mikecelica
Joined Jan 31, '07
I think I found the place where the rca lines WERE. There are 6 (bit thicker than speaker wire) wires all in one harness but have been cut off from the base leaving only .5inch of each sticking out. So should I get some rca wires and just extend them or is it more to it than that?
post Aug 28, 2008 - 4:53 PM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
QUOTE (mikecelica @ Aug 28, 2008 - 5:33 PM) *
That is / was the rca outputs. Good luck splicing them. There is a center conductor and a shield surrounding it, can be tricky to splice.
If I was gonna do it, I would open the case and solder new rca's to the board.
post Aug 28, 2008 - 6:34 PM
mikecelica
Joined Jan 31, '07
Yea thats what Im going to do, open it up and put new rca's. One other thing tho, ppl that have alpine decks. Theres a warning label on the yellow (power) wire of the deck that says to connect directly to battery. Is it ok to connect the end of that yellow wire to some 8gauge power wire then connect to battery or should I try to find wire the same size as the yellow wire? * What size is the yellow wire (Its the same size as all the other speaker wires) Is it 10 gauge? 12,14,16,18? thanks
post Aug 28, 2008 - 8:40 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
The yellow wire is a constant power, whereas the red is the ignition power. If you bought a Toyota wiring harness to wire up the Alpine harness with, both of those will be there.
post Aug 28, 2008 - 9:46 PM
mikecelica
Joined Jan 31, '07
Ok but what size is the yellow wire? I need to extend it and run it thru the firewall and directly to the battery, it says a warning label not to connect power to the dash power wire but to do it directly to the battery.
post Aug 29, 2008 - 1:21 AM
GTSOwner
Joined Sep 28, '06
From Montreal, QC, Canada
I think I found the place where the rca lines WERE. There are 6 (bit thicker than speaker wire) wires all in one harness but have been cut off from the base leaving only .5inch of each sticking out....
NO... *slaps forehead* Can someone hit the previous owner in the head with a shovel?
You'll be fine running constant power off of the harness.
This post has been edited by GTSOwner: Aug 29, 2008 - 1:22 AM
post Aug 29, 2008 - 2:18 AM
azn87
Joined Aug 2, '06
From bay area
i got alpine 9857 deck with alpine type R 10" and a m450 amp from alpine with stock speakers for the doors and rears, sound very good with loads of bass
post Aug 29, 2008 - 5:38 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
You don't have to hook it up directly to the battery, use the constant power wire from your factory wiring harness.
-Matt
post Aug 29, 2008 - 8:28 PM
mikecelica
Joined Jan 31, '07
I just finished setting eveyrhting up, turned it on...nice CLEAN sound, soo many features and sound adjustments tho that I gotta play with to make everthing just right.. BTW I ended up putting new rca's into the board and hooked up the power straight to the battery with 8gauge wiring.
This post has been edited by mikecelica: Aug 29, 2008 - 8:28 PM
Lo-Fi Version Time is now: August 29th, 2026 - 2:44 PM
