> My first engine real engine "problem", Nooooo! My car is getting old!
post Sep 4, 2008 - 9:48 AM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
Ok my car is eating up oil. I'd say it goes through 3qts in ~4months. For a long time I did have an oil leak and I knew it was because of that. But my mechanic "fixed it" awhile ago. Well I definatly does not have an oil leak. But it still eats up oil. No white smoke coming out of the exhaust (if there is its very very very minimal). I have not checked my plug to see how it is firing.
So what is the most likely problem? Is it Valves? It is a head gasket? Is water getting into the oil?
PS: I'm getting depressed about my car getting old and I'm starting to look for a replacement frown.gif
BMW 335i Coupe is my choice if I do pull the trigger.... yeah I know... all my family and friends keep hinting at me to upgrade.
This post has been edited by UTSlickVic: Sep 4, 2008 - 9:49 AM
Replies (1 - 5)
post Sep 4, 2008 - 10:23 AM
D-Man
Joined Jan 18, '08
From Houston
Check your radiator fluid for oil.
Damn D-Man - most impressive.
post Sep 4, 2008 - 12:20 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
It sounds like your car is using oil at a perfectly normal rate, assuming it's your daily driver. STs are notorious for burning oil some, and it sounds like while yes, your car is getting old, it's really not doing anything too abnormal. Seals age, so there's going to be some slight leaking which burns off while you drive. You could replace all the seals (IIRC it's the valve seals in particular) but really, you're not going through oil enough to warrant the expense and labor. I've got around 238k on mine now, with about 110k on the engine, and I'm going through 3 quarts at about the same rate as you, maybe a little faster (but I commute 40 miles a day 5x/wk) At oil changes I'm usually barely above no a read.
post Sep 4, 2008 - 9:55 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
140K miles and i loose less than a quart over the duration of a 5000 mile oil change.
try a different oil
post Sep 5, 2008 - 10:51 AM
Taskbot
Joined Jun 6, '08
From Hamiltron, Ontario
Yeah mine burns a bit of oil aswell. There was a thread a few weeks ago about a ST burning oil (check it out, there's some cool suggestions on it) but yeah it sounds like you're burning an average amount of oil. 1.5qt per 2 months does not seem that bad at all, mine burns about the same if not a bit more. I don't think this kind of problem warrants having to go through the trouble (or FUN biggrin.gif) of finding a new car. Besides, you have a lighter car that is better on gas which means more money in your pocket, you don't need to do any "upgrading"
(\__/)
post Sep 5, 2008 - 11:24 AM
DEATH
Joined Dec 19, '07
From tx
Good luck "upgrading" the looks - you have a very nice looking car and they just don't make them this pretty anymore IMO.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
Lo-Fi Version Time is now: May 8th, 2026 - 9:12 PM
