Nov 16, 2002 - 12:49 AM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 30, '02 From North Carolina Currently Offline Reputation: 0 (0%) |
Well I was on my way to work today and I was behind a garbage truck and it had mud all over it and a big piece of it came off and hit my front piece. It knocked 3 chips out of it right where the 2 pieces meet. So guess im gogin to need a repainting.
-------------------- 99 Toyota Tacoma
Nov 16, 2002 - 1:32 AM
![]() Enthusiast ![]() ![]() Joined Nov 8, '02 From Mongtomery Alabama Currently Offline Reputation: 0 (0%) |
dude...that sux about what happened to your ride...how much do you think it'll cost to get it fixed?
Nov 16, 2002 - 1:33 AM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 30, '02 From Franklin,Tn Currently Offline Reputation: 0 (0%) |
Damn Jason, I know how careful that you are with that front. I bet that you were pissed. Hope that its not to much buddy.
Bryan |
Nov 16, 2002 - 2:50 AM
Enthusiast ![]() Joined Oct 21, '02 From florida Currently Offline Reputation: 0 (0%) |
yeah dude that sucks man, do you have a warranty on the paint of your front bumper?
Nov 16, 2002 - 3:07 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 13, '02 From Hawaii Currently Offline Reputation: 0 (0%) |
That really sucked a$$...I would snap if I were you.
Nov 16, 2002 - 3:10 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
You can fix this your self for about $20 as long as that is the factory paint that you have on the airdamn.
In your photo it looks like your car is still factory white. If it is then duplicolor sell a paint that is a exact match.. can't remember the name I think is is the Import white "Polar" but am not sure..NEwayz Always wet sand primer and paint Sand down the area (300-400grit) where the chips are so the piece is nice and smooth.... be sure to mask off areas that you don't want affected by doing this. Use a sanding block. Primer the piece with an automotive primer. Do 3-4 layers of this. Sand Primer (300-400grit) with a sanding block until the primer is flush with the original paint. Paint 4-5 coats of Duplicolor... sand with a sanding block (800-1000grit) inbetween coats... be gentle. Paint with clearcoat 3-5 coats... until it matches original paint.. Allow to cure for 48 hours. Use rubbing compound to smooth the new paint into the original. buff using wax. This works really good but takes a little time. -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Nov 16, 2002 - 2:46 PM
Well I guess ill jsut touch it up or now and get it repainted before summer comes in, might buy the add on lip for the back adn get both painted
| Lo-Fi Version | Time is now: March 26th, 2026 - 6:13 PM |
